Sanyo DP42849 - No Power At All
  • NihonNoir
    • Jan 2014
    • 231
    • US
    #261
    Re: Sanyo DP42849 - No Power At All
    Well, I've emailed him and see if he'll take any less. I'd be surprised if it's gone - most people equate Sanyo with no-name brands, even though it used to be a quality Japanese brand before being sourced to China. We'll see.
    Here's what I got:
    Point 1: "1"
    Point 2: 0.00
      OK, can you see part number on Q303?
      • NihonNoir
        • Jan 2014
        • 231
        • US
        #263
        Originally posted by tom66
        No picture, there is a chance that big inverter transformer is bad, (if no backlight) but you can swap them over, it's just a lot of work.
        Are there any on-site tests that I can do that will give me a better idea of which board is the issue?
        Let me see if I can find Q303.
          Q303 right next to those points you were ohming out.
          If the faulty TV has no backlight but makes sound, then it's likely the transformer.
          If it has a backlight but no image, it's not the transformer.
          • NihonNoir
            • Jan 2014
            • 231
            • US
            #265
            Wow, that thing is tiny.
            I can make out a 2, and then a T, and then what looks like another 2 turned once counter-clockwise.
            • NihonNoir
              • Jan 2014
              • 231
              • US
              #266
              So would shining a flashlight into the screen be a good way of testing for an image without backlight?
                Yes.
                  Likely MMBT4403.
                  I traced out what I think the schematic for this area is, reverse engineered.
                  Try and follow Blue 1 and Blue 2, as indicated. They go off the edge of the image.
                  When U303_ON_OFF is pulled LOW, the main controller will start working.
                  PFC voltage is ALWAYS active, provided Main VCC is OK.
                  I suspect Main VCC is NOT OK.
                  • NihonNoir
                    • Jan 2014
                    • 231
                    • US
                    #269
                    I'll give it a try. In the meantime, here are some better shots of that area.
                      I've traced some of those lines, I think one goes to J16 and other to IC203 or IC303.
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #271
                        Blue 1: Looks like it goes to IC303. Then through IC303 to J37.
                        Blue 2: To J16. Then Q602. Not sure if it stops there or keeps going.
                        • NihonNoir
                          • Jan 2014
                          • 231
                          • US
                          #272
                          That's what I got too!
                          • NihonNoir
                            • Jan 2014
                            • 231
                            • US
                            #273
                            Is there anything else I should try or test?
                            Thanks!
                              Plenty more; but I'll pass over to others for now for a good night, and will try and post tomorrow. Should this not happen please bump the post.
                              • NihonNoir
                                • Jan 2014
                                • 231
                                • US
                                #275
                                Bump.
                                  Yep, thanks for that, completely forgot
                                  Anyway, check voltage across C603 and ZD601.
                                  Also, voltage from J16 to the -ve of small cap.
                                  Also, voltage across primary side of IC302 and IC303 optocouplers.
                                  (Board installed, same procedure with green light.)
                                  We are closing in on the fault with any luck. It might be Q602 or the optocoupler which is bad.
                                  • NihonNoir
                                    • Jan 2014
                                    • 231
                                    • US
                                    #277
                                    Thanks. I'll work on this later and report back.
                                    • NihonNoir
                                      • Jan 2014
                                      • 231
                                      • US
                                      #278
                                      C603 - 0.06
                                      ZD601 - 0.12
                                      J16 - .03; goes up to .06 when power button is pushed
                                      I don't know how to test the ICs.
                                        OK, looks like IC601 is not switching at all.
                                        This is getting a bit tedious, but part # of IC601?
                                        • NihonNoir
                                          • Jan 2014
                                          • 231
                                          • US
                                          #280
                                          2A09303
                                          5541
                                          Not positive on that 2, but I'm not sure what else it could be.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
