Toshiba 32AV625D no image, sound and backlight works.
    Hi all, this is my first post and I would ask for help with my TV.
    When I turn the tv there are no image but the sound works perfectly and the backlight works too.
    Sometimes the image appears after a while.
    I tried to change the T-Con board with no results.
    If I keep it about 5 minutes and I turn off and turn on quickly the image appears freezed for a second.
    Thanks in advance!!!
    Re: Toshiba 32AV625D no image, sound and backlight works.
    try connecting another tv to the this one via scart lead,does the picture look ok?if good should confirm mainboard video is working.
    was there any change with new t-con?,or same?
    could be duff new t-con,or quite commonly panel failiure
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      Hi multimeter, thanks for your reply.
      With there werent any diference with the new t-con.
      I have another lcdtv but i don't know how to do the connection.
        just scart out from the faulty tv into test tv via the scartt input,
        if the picture is the same the video processor is knackerd,new main board
          Ok i get it.
          The other tv shows the same, nothing.
          The faulty tv has no in-source when i tried.
