Alba 32880hdf Flashing standby
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Alba 32880hdf Flashing standby
    did you unzip the files in the download?
    • anotherdude
      • Feb 2013
      • 488
      Originally posted by multimeter
      what EEPROM is on the main board?,maybee one that can be reset,using a pin to pin short,that might bring it back
      listed as u162
      schematic says NAND512-A
      I can't make out the whole of the model number on the board as it's located under the expansion slot
      • anotherdude
        • Feb 2013
        • 488
        heres a picture or 2
        • anotherdude
          • Feb 2013
          • 488
          yes of course, It seemed to be going through it but i'm guessing me pulling the power (too early maybe) after no activity was the issue or incorrect firmware
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            ^^ thats not an EEPROM ..
            fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
            please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
            • vinceroger69
              • Mar 2012
              • 6714
              #26
              whats the full main board number you need i will look in my box of boards tommorow also is there another source for the firmware maybe the member in the other thread who says he has it?
              • anotherdude
                • Feb 2013
                • 488
                #27
                17mb62-1 v1
                • anotherdude
                  • Feb 2013
                  • 488
                  #28
                  sorry my bad should of realised
                  can't seem to see it my eyes are pretty poor
                  can you see it here so i can take a photo just so i know which one to picture
                  • anotherdude
                    • Feb 2013
                    • 488
                    #29
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      #30
                      only one i can see there is the 8 legged chip to the left of the yellow sticker,prob closet to the proccessor ,is that it ?,any part number,eeproms are normally 8 pin chips
                      • anotherdude
                        • Feb 2013
                        • 488
                        #31
                        only one i can see there is the 8 legged chip to the left of the yellow sticker,is that it ?,any part number,eeproms are normally 8 pin chips
                        that is it, listed as serial flash?, missed it from the beginning
                        • multimeter
                          • Jan 2011
                          • 739
                          • united kingdom
                          #32
                          spi? flash chip part nu,starts like 24c******?
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            #33
                            ahh,seen pic lol,try googling for a pin configuration,some you can short 2 pins,power tv on and remove shorts this reboots the eeprom,not on all though
                              I have a 17MB62-2.6 with fried processor but OK firmware chips. I can send you the dud board for postage cost, perhaps you can make some use of the flash chips.
                              • anotherdude
                                • Feb 2013
                                • 488
                                #35
                                can't find anything from the model number in the picture
                                the schematic lists it as mx25l512
                                shows the pinout but no info on how to go about resetting them
                                • anotherdude
                                  • Feb 2013
                                  • 488
                                  #36
                                  cheers tom, might take you up on that
                                    Just be aware my board is a FHD 32" LG panel, yours could be Samsung 32" 720p? Cannot guarantee F/W or panel settings will be compatible.
                                    • anotherdude
                                      • Feb 2013
                                      • 488
                                      #38
                                      thanks tom, be cheaper/easier to send me the chips if thats doable?
                                        Doesn't make much difference - the chips have the F/W on them for that set up -- now on some Vestels you can change panel settings, cannot confirm yours will be able to do this.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          just had a look in my shed at all my main boards sorry but non match the number at all not even close.
                                          • PNI E.
                                            Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                            by PNI E.
                                            Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                            03-17-2025, 04:23 AM
                                          • Willem01
                                            TV not powering on - with standby red –led flashing
                                            by Willem01
                                            Error – TV not powering on - with standby red –led flashing
                                            Model- LEDTV – 39T3500
                                            Power boarD - shg3206a-101h
                                            I have read through the Basic LCD TV and Monitor troubleshooting guides.
                                            https://www.badcaps.net/forum/showthr...956#post305956, I am no ELEC engineer but can use a multi meter and soldering iron
                                            In the meantime I could not see any damage to any caps on the cold side of the power board, so I have replaced all of them.
                                            Unplugged the power connector on the board, I plugged the power cable in waited...
                                            02-27-2021, 08:23 AM
                                          • STKR123
                                            Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                            by STKR123
                                            As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                            I wonder if re-flashing the BIOS might be of any use here.
                                            As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                            There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                            11-03-2024, 06:58 AM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • howardc64
                                            HiSense 65H6510G no boot
                                            by howardc64
                                            TV standby light flash once after plug-in AC power. Then silent. No backlight, no LCD image on flash light test, no SPDIF light.
                                            All PSU voltages to main looks good (12v, 20v (label says 18v but is 20), standby voltage) Probing main board shows what appears to be a DCDC converter (MSH6103A can't find datasheet) providing 5v, 3.3v and 1v. 5v present to the standby light power switch board.
                                            These HiSense TVs appears to have lots of firmware corruptions that takes out the main board either through smartTV use or firmware update. Used main board...
                                            03-29-2023, 12:52 PM
