Panasonic Plasma TV LED blinking 12 times
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TV LED blinking 12 times
    Originally posted by PaulF
    The voltage increases gradually over a couple of seconds and reaches a max of 1.56v which is steady for probably about a second then shuts off. Will do the test again and take better note of what happens. tw2005 I agree with what you are saying, I'll check out Q2301.
    I did identify the FET as 25K2510, I just can't seem to find a data sheet for it to see it's spec in case it is faulty and need to find an equivalent.
    Thanks for the help guys.
    if you keep typing 25K2510 when it's 2SK2510, you won't. i get a page full of hits, the first being a spec sheet.
    One would think if it takes 2 secs to get to 1.56v, holds for a sec then shutdown, PSU fault is looking likely.
    Did a quick search here for equivalents http://alltransistors.com/mosfet/crs...024&caps=MP45F
    2SK2498, 2SK2512
    Type Designator: 2SK2510
    Type of 2SK2510 transistor: MOSFET
    Type of control channel: N -Channel
    Maximum power dissipation (Pd), W: 35
    Maximum drain-source voltage |Uds|, V: 60
    Maximum drain current |Id|, A: 40
    Maximum junction temperature (Tj), °C: 150
    Maximum drain-source on-state resistance (Rds), Ohm: 0.024
    Package: MP45F
    • PaulF
      • Jan 2014
      • 17
      • United Kingdom
      Doh,
      Sorry, will have to get some glasses. even when I saw it in your message I read it as 5 instead of S. Good job there is someone around to put me right.
      • tw2005
        • Oct 2011
        • 6458
        Doh,
        I stopped short of suggesting that, all I know is once you have them , they never seem strong enough.
        Don't worry, someone else would have pointed it out. The fact 2 of us posted 2SK2510, you had me wondering especially with the , can't find the datasheet comment.
        • PaulF
          • Jan 2014
          • 17
          • United Kingdom
          TP2302 does indeed go high to flag the SOS.
          I nonitored the G-S voltage of mosfet Q351 with a scope, this never rose above a fraction of a volt during switch on & just looked like noise. This obviousy isn't sufficient to turn the device on hence 15v at D and no 15v at D.
          I then monitored pin 4 of MC351 which is marked 15V_ON, which i assume is the signal to turn Q351 on, this remained constantly 0. This in turn comes from MC701.
          I am probably at the point now where I am beginning to condider that I'll have to replace the power board, unless anyone has any suggestions.
          • PaulF
            • Jan 2014
            • 17
            • United Kingdom
            Typo: Should have been 15v at D and no 15v at S
            • tw2005
              • Oct 2011
              • 6458
              No real idea, just wild guesses. Is there 15V at pin 8 of MC701 . Micro fuse IP351 on the underside, ?
              • PaulF
                • Jan 2014
                • 17
                • United Kingdom
                #27
                You could be on to something there. Just checked pin 8 of MC701 and it gets up to 3.2v only. Will lift the board out and check IP351 as you suggested.
                • PaulF
                  • Jan 2014
                  • 17
                  • United Kingdom
                  #28
                  Just studied tthe diagram again. I have 15v at TP7. Between pin 8 of MC701 and TP7 are: R367, R351 and and unidentified symbol. Will check through that part of circuit.
                  • tw2005
                    • Oct 2011
                    • 6458
                    I don't think IP351 is the fuse for the 15V in on pin 8 but the diagrams seem to suggest some kind of fuse for that, I can't get my head around it. But if you got 15V at TP7 then that passes through what appears to be a fuse, then R351 10.5K, then R367 10k then pin 8 so not sure if 15V_in means 15V should be at pin 8 or not to be honest.
                    looking at p65, T301, S4a.
                    • tw2005
                      • Oct 2011
                      • 6458
                      LOL, Something tells me you understand this better than I
                      • PaulF
                        • Jan 2014
                        • 17
                        • United Kingdom
                        #31
                        I think pin 8 of MC701 is the sensing signal for the 15v supply so what I measured could be correct.
                        It seems like MC701 is not giving the signal to turn on the 15v to the H board, wether thats due to a fault on MC701 or due to it thinking there is a fault elswhere is difficult to know.
                        Without knowing what all the pins should read it could be difficult to know if things are right or wrong.
                        I'll have to decide if it's worth risking buying another P board (I've located one for about £60) or havee a trip to the local tip. I don't mind buying the new board if I'm sure that's where the fault is.
                        Thanks for all the help.
                        • tw2005
                          • Oct 2011
                          • 6458
                          yeah , I had a bit more of a look and I was starting to think the same, with 15V_in, 15V_on,15V_out and those resistors the likelihood of 15V meant to be there was looking slim. So I was half expecting you to come back with that.
                          I was guessing, when you said 3.2V , a logic high crossed my mind.
                          makes me wonder if 3V was injected into MC351 pin 4 what would happen?
                          I know what you mean, getting a PSU and still having the fault would annoy me too if that happened.
                          Anyway you never know, someone might come up with something. It'd be great if you knew someone with the same TV/ PSU for a quick swap/test.
                          ETXMM655MEH
                          • PaulF
                            • Jan 2014
                            • 17
                            • United Kingdom
                            #33
                            I was thinking along the same lines as you abou injecting a voltage into MC351 pin 4 but was a bit nervous of doing it in case the reason for it being absent at the moment was for protection due to a fault elsewhere, if I inject a voltage I could cause more damage.
                            • PaulF
                              • Jan 2014
                              • 17
                              • United Kingdom
                              #34
                              Success.
                              I fitted a replacement P board and it's all working again.
                              Shame I replaced the H and DG boards first. I put the originals back in so if anyone needs a H or GD board, let me know.
                              All the best to all on the Forum who helped to diagnose the problem.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Success.
                                Good to hear, shame we did not nail it to a component.
                                • EIEIO
                                  • Jan 2014
                                  • 6
                                  PaulF, I'm glad to hear you fixed your TV. (Sorry to hijack your thread earlier, but I was new to this forum and couldn't start my own).
                                  I have different boards on my TC-P42S1 tv, but tried the same as you as suggested in the documentation I could find. I sent my A board in to be repaired and it was returned with a note that it passed all tests and to check other boards. I'm leaning now towards the P board.
                                  All standby power readings are good on my TV and the A board does send a 3.2V "panel_main_on" signal back to the P board, but the tv eventually shuts down and I still get the 12 blink code.
                                  Any suggestions before I search for a P board?
                                  • EIEIO
                                    • Jan 2014
                                    • 6
                                    Well, I didn't get the same results as PaulF. My replacement P board arrived today and after installing it, I have 10 blinks rather than 12. Following that flow chart, I come to the end and it instructs to replace A board.
                                    Just to confirm, that was my first diagnosis and had sent my A board to Moduslink for repair. They found no problem with it and said it ran for several hours in their test set. They want me to send both my original P and A boards together for testing side by side. It's about $160 each to repair. If both are bad, $320 almost buys me a new set these days.
                                    Any thoughts or suggestions?
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      I'm thinking both PSU could be faulty especially since they tested the A and they say it passed.
                                      • EIEIO
                                        • Jan 2014
                                        • 6
                                        That's kind of what I was thinking. The P board I bought was from a different outfit and came with a 6 month warranty. I guess I'll either send it back for exchange or take the Moduslink (who has been very good to work with) route.
                                        • EIEIO
                                          • Jan 2014
                                          • 6
                                          FYI, a replacement P board was sent to me and my TV is now working again. Total cost of repair was $86 for the P board and a $50 testing charge on the A board that was originally thought to be the problem.
                                          Thanks Badcaps forum!!
                                          • ahmarzo
                                            Hp 15-cs laptop 5 times dc jack blinking white
                                            by ahmarzo
                                            I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                            First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                            Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                            But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                            12-28-2024, 04:46 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • fourroses73
                                            Panasonic Plasma TX-P46VT20 blinks 10 Times
                                            by fourroses73
                                            Hi all folks.
                                            My old Plasma TV blinks 10 Times when i try to start it. Its now 2 weeks that i search like an old donkey on internet and i try everything.
                                            Nothing smell or looks like burned. I think its the A board, but i did not find more infos how search error on the A board. Replace it its not an option: I dont find part for this TV in my country and if i give it to a repair shop its to expensiv...
                                            What i have measured:
                                            Vsus and Vda are ok
                                            Pin1 of connector P7 : 5V ok
                                            Pin1 and 9 of connector P6: 16V in place of 15V but...
                                            12-03-2020, 05:28 PM
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
