Epoxy Replacement ?
  • mmartell
    • Oct 2013
    • 3189
    Epoxy Replacement ?
    What are people using for ic pin insulation when replacing an ic ? I don't think what is on there originally is the epoxy I'm familiar with as that stuff hardens like steel.
    I'm in the middle of a buffer repair and would like to make sure there is no shorting/arcing when finished.
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Epoxy Replacement ?
    I have only ever done one. I used candle wax for testing. Then I thoroughly cleaned it and used neutral cure silastic. It needs to be carefully pushed in between the pins.
    A flowable silastic would be better.
    • johnboy1313
      • Nov 2012
      • 1959
      https://www.badcaps.net/forum/showthread.php?t=33750
      • mmartell
        • Oct 2013
        • 3189
        Thanks for that johnboy. What did you end up using ?
        I'm tempted to use hot glue myself as it's readily available and I'm essentially lazy lol.
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • the_rem
          Unknown transformer : how to find a good replacement part ?
          by the_rem
          Hello guys,
          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
          04-23-2025, 01:48 AM
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
