Panasonic 55VT30 - blinking 7 times
  • MileHigh
    • Dec 2013
    We've been having some issues with the upper half of the screen flickering, especially with whites. This stopped for about a week and then on Saturday night, the TV popped and shut off. Of course the LED is blinking 7 times. I have ordered a SC board from ModusLink as it seems they are hard to find. I am hoping to have the TV repaired by this weekend. Any tips would be appreciated on checking the SU/SD boards as well.
  • ahmarzo
    Hp 15-cs laptop 5 times dc jack blinking white
    by ahmarzo
    I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
    First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
    Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
    But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
    12-28-2024, 04:46 AM
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • CoinCoin88
    Panasonic PF50G20S blinking 13 times
    by CoinCoin88
    Hello there,
    Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
    Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
    06-30-2023, 05:43 AM
  • NConstantinou
    DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
    by NConstantinou
    I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
    WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
    BIIOS PINS 7,8 I HAVE 3.3V
    IS THE PROBLEM ON MOTHERBOARD OR BIOS.
    08-21-2025, 03:23 AM
  • NolesFan
    Sony kd-85x85j LED blinking red 6 times
    by NolesFan
    I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
    03-16-2025, 11:50 AM
