alba lcd32880hdf (fixed)
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    this one came in with flashing blue red standby led.
    power supply 17ips10-3 v.1,mainboard 17mb45m-2
    the power supply has intergrated inverter bit of a pain,no markings for voltages etc,also used in bush,sylvania etc,it has a touch panel on the side for the usual adjustments ,.
    these NORMALLY suffer with the inverter output ceramic caps (3kv),on c231 &c230,an insulation test confirmed they were fine,and capacitance was within tolerance,all other lytic caps tested for esr returned good results.
    i had all stable voltages ,but no voltage in inverter section??although a fluctuation on the standby voltage was due to the led's flashing in time with the flucuation.
    it was hit and miss knowing what voltage goes where,it is a vestal afterall!things seemed fine as a guestamite.
    i decided to do component testing in the area of the inverter,from the smpt there are 2 ultra fast recovery diodes in parallel .
    floating my scope probe over the smpt was showing a waveform,this indicated to me that there is life there.
    i carried through checks on these diodes and found a shorted diode,(in circuit),removed from circuit and tested the same,(d105)a uf5402,upon scabbing through my junk bin,i found one of the same spec,installed,
    the result.
    she fired right up,full backlights,menus the lot.
    on soak now just to check she dont cough,so far so good.
    another saved from costly landfill!
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
    Re: alba lcd32880hdf (fixed)
    Thanks for posting but did you use expensive meter? Otherwise you are not a pro and it is not good enough for working on TV! The Greek may tell you otherwise since you are not using expensive meter, you cannot possibly fix anything with cheap meter!
    You cannot even use cheap meter to check the fuse!
    https://www.badcaps.net/forum/showth...711#post409711
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      funny enough i tracked it down with an old analogue meter set to x10k cost be around £20 for the 2,as my fluke was in work,a good way to check for breakdown is to use 2 meters in series,which gives you a higher output voltage at the probes.
      im waiting for his website,where you have to log in with your bank statement number,anything less than a hundred grand and your stuffed !!
      its not about using cheapish test equipment
      its how you use it .......,ever heard the saying"you have a black cat,i have a black panther"?..rings true dont it
      in all honesty you and tom are the couple i enjoy reading about over the net,and not just on badcaps.and id stand by them !i like how you guys think outside the box.
      everywhere i look about the "said"person elsewhere else seems to flag up a lot of misery,i wonder why?................!
        Haha I must have replaced/seen SO many bad diodes on Vestels... let's think
        17PW25-4 (x 2): 11 x UF5408 each
        17PW26-3: 1 x UF5402 + 1 x generic ultrafast 1amp
        17PW20-1: 2 x 3amp schottky
        17PW15-8: 2 x 3amp schottky, 1 x 1amp schottky
        A friend of mine has fixed quite a few PW26's with shorted diodes too.
        They are truly the bane of modern Vestel sets.
        • cossiejay
          • Nov 2010
          • 83
          i have one of these tv with 100% same problems I have removed diodes all fine and replaced the 2 caps by the invertors still will not come on
          • cossiejay
            • Nov 2010
            • 83
            33uf 100v cap on live side changed and bingo straight on
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              What Psu on ?
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                Originally posted by ReeceyBurger123
                What Psu on ?
                Maybe this thread
                https://www.badcaps.net/forum/showth...838#post628838
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  There is no 33uf 100v cap on the 17PW26 what I find funny is he claimed he checked them all.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    i was thinking the 17ips10-3 power board im not sure lol.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      I have no idea what hes on about at all ohh well lol
                      • cossiejay
                        • Nov 2010
                        • 83
                        17ips 10-3 which is what this post is about if you read all the comments you would realise that ,I also never mention checking all the caps on this board
                        • cossiejay
                          • Nov 2010
                          • 83
                          and my post that you refer to also clearly states they have different boards please fully read posts and comments before jumping to conclusions one of you have made your self look very silly
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Well the other post is the same Tv ffs what do you expect us to think lol
                            • cossiejay
                              • Nov 2010
                              • 83
                              they are both the same tv ffs read THE POST CORRECTLY I STATE THEY HAVE DIFFERENT BOARDS IN THEM not fcuking hard is it
                              • michael dranfield
                                • Jan 2016
                                • 232
                                • England
                                the result.
                                I would not count on testing them HV caps too much , I have put 3750V volts on them before and they dont break down, the value on test is fine but put a new one in and it always cures the fault ???????????
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Haha go fuck your self think im helping your useless ass swearing at me, you little prick good luck with your Tv twat
                                  • cossiejay
                                    • Nov 2010
                                    • 83
                                    swearing whu jump to conclusions before you read the full post with your smarmy answers I have noticed on a few adds you come across as a complete know it all idiot
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      ohh for crying out loud.....lets all go to a neutral corner and come out friends again.
                                      <--- Badcaps.net Founder
                                      Badcaps.net Services:
                                      Motherboard Repair Services
                                      http://folding.stanford.edu/
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Im done btw Topcat he sent me a Pm calling me a cunt the little prick haha
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • eccerr0r
                                          A modified sine wave inverter + a grid tie inverter?
                                          by eccerr0r
                                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                          08-31-2023, 09:14 PM
                                        • caseyjay_48
                                          Sony KDL-46BX450 Inverter Troubleshoot Logic
                                          by caseyjay_48
                                          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                          09-23-2022, 08:08 PM
