Re: Phillips 52PFL5704D/F7 main board
There are tiny tiny pins come out at the bottom of the white plastic, the pins are surface mounted and you can see that they are connected to some of the copper traces with vias on them, the vias do not have solder mask on the them so you will not get good electrical contact to take the readings.
But let's says that we see big different in the voltage readings, the question will be how to figure out which component is bad, I think the bad part is the IC on the right side of the board.
