sony kdl-52lx900 3 blink problem
  • handycap
    • Jan 2014
    • 21
    • australia
    Hi, guys.. I need your help..
    I have sony kdl-52lx900, first my tv turn on with the green light but no picture no sound but sony logo light up, after 1 minutes my tv turn off and turn on straight away again and again, so i tried to reflow the chip of the mainboard with heat gun i thought i saw smoke from the main board, i put the mainboard to the tv and connect everything, now my tv blink 3 time standby light, like standby light blink 3 times pause standby light 3 time pause....please for your help guys...
    Thanks so much
  • handycap
    • Jan 2014
    • 21
    • australia
    Re: sony kdl-52lx900 3 blink problem
    This the pic of power supply
    I tested the dc voltage and only 3.3 voltage is on, other like 12 voltage and 12 voltage to tcon is zero on multimeter, sorry this is my 1st time used the multimeter.
    Do you guys think it can be fix by replace transitor, diode, capacitor on power supply?
    And what should I check in power supply using multimeter?
    Thanks guys
    • handycap
      • Jan 2014
      • 21
      • australia
      Thanks guys
      Please helpp me to solve it....
      • selldoor
        Slow Learner
        • 7870
        Read up what the Sony 3 blink error code means for this set.
        I think we need a picture of both sides of the main board to see if it looks damaged from the heat gun- have you had success doing that before? why did you try that first?
        As you ONLY have the 3v it suggests the main board is at fault but I dont know what the blink code is for that set.
        • handycap
          • Jan 2014
          • 21
          • australia
          I did heat gun for my ps3 mainboard and it work, so I tried do it again to my sony tv.
          the meaning of the 3 code is Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
          And also I did test to the 3 transistor near the dc connector, it look in multimeter 0.302, 0.200, 0.03.
          Is it possible problem from the transistor?
          I wish not the mainboard broken cause I couldnt find a mainboard like this in jimmyshop.
          thanks for your help
          • handycap
            • Jan 2014
            • 21
            • australia
            This my mainboard picture:
            Front :
            At the back :
            • handycap
              • Jan 2014
              • 21
              • australia
              Front :
              At the back :
              Help please...
              • selldoor
                Slow Learner
                • 7870
                I really dont know where to start obviously torching your main board could only help if you knew that was a problem as it is you may have damaged it? and the pictures are not really clear enough to see.
                What I can see is multi references to fuses F**** have you located and tested them all.
                On a board that size its not much good saying you have tested a transistor you either need a good picture and a visible board number or you post a picture and circle it. You also need to quote the part number and if possible find a datasheet for it. You would need all that anyway if it is faulty and you have to replace it.
                Have you found and tested R 672 - you will need to lift one leg off the board to do that.
                • ChristianBr01
                  LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                  by ChristianBr01
                  I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                  The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                  What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                  04-23-2025, 01:48 AM
                • noinimod
                  Sony 55X900E no standby light, no power. Replaced mainboard already
                  by noinimod
                  No standby red light, nothing
                  This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                  Disconnected JK3 power board from main board, checked voltages on all the pin outs
                  At a few pins I can see the power supply providing 19.5V to the main board
                  Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                  LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                  12-22-2021, 12:58 AM
                • SkishyIshy
                  Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                  by SkishyIshy
                  Hey All,
                  I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                  I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                  I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                  03-17-2021, 11:44 AM
                • macinjosh
                  Sony KDL40EX501, won't power on, no standby light
                  by macinjosh
                  Hello all,
                  My Sony Bravia recently (after a storm) shows no red standby light at all. Taking it apart, I noticed that one of the ICs on the main board seemed to have a hole in it, so I replaced the main board.
                  However, I still have the same problem.
                  I've looked at the SONY technical flowchart for these models, but am stuck at what to do at this point. Here's what I've done:
                  1. I've verified that the power supply board is getting 120v AC.
                  2. Verified standby voltage, about 3V DC on pin 1 of the power supply.
                  3. Verified...
                  08-10-2021, 11:44 AM
                • AleMonti
                  LG 55EG910V - no power and no standby light
                  by AleMonti
                  I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                  I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                  The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                  After checking the basics I did the following:
                  • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                  11-04-2024, 05:02 PM
