HP Plasma PE0000
  • jasonflippin
    • Jan 2014
    • 52
    Re: HP Plasma PE0000
    How can you tell which is VS? Assuming it's the screws above the power plugs? (pic 3 a few posts ago)
      They should be marked, are they not?
      • jasonflippin
        • Jan 2014
        • 52
        I do not see any obvious markings
        • jasonflippin
          • Jan 2014
          • 52
          Ok, I found them. When I turned it up to higher 180's it became more pixelated. When I turned it down to 160's the picture would clear up and not do its static pulsating thing. The only thing I have to test with is an old xbox and when playing a game now it is clear as can be with none of this pulsating. But, when I pause the game it is doing the static pulsating thing (which previously when it was a still picture it didn't do it but when moving it did). Not a huge deal, making progress. Any idea why lowering the recommended voltage is helped somewhat? Worth tweaking the VA?
          • jasonflippin
            • Jan 2014
            • 52
            Partially true anyway. The static still exists every now and then even when turned down low. One other thing to note, I checked the ZSUS heat sink and it is so hot I can't even touch it after 10 minutes of usage or so, does that seem normal?
            • jasonflippin
              • Jan 2014
              • 52
              Any suggestions?
              • freakaftr8
                • Oct 2012
                • 3743
                Well the Ipm is supposed to get warm. I don't know about hot thou. Did you use heat transfer compound?
                • jasonflippin
                  • Jan 2014
                  • 52
                  I re-used what was on the heat sink which there was a generous amount but it was not new. I can try to rig up some fans or something on it to rule it out for now if you think that would be helpful.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    I really don't think it's going to make a difference in the picture quality you're having but they're still could be an underlying issue on the ZSUS board. but it definitely looks like an adjustment issue. when I get a TV and sometimes people like to play inside and you never know what they turn
                    • jasonflippin
                      • Jan 2014
                      • 52
                      Would it have anything to do with the VR adjustments?
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        It could. Try getting a hold of a service manual. Did you verify voltages yet?
                        • jasonflippin
                          • Jan 2014
                          • 52
                          ya on the VS (187) and VA (65) I have them set. It is very flickery when I have them set to this but figure the adjustment must be somewhere else since these are set correctly.
                          • jasonflippin
                            • Jan 2014
                            • 52
                            My concern is I wonder if I screwed up the Z-SUS board when I heat it up to get the old IPM off. I also had to re-solder a few pieces back on that board that fell off when it was heated. I am fairly certain I got everything on there good though so wouldn't think that would be the issue. I just wonder if there is a way to at least rule this work out one way or another so I know if I did that right or wrong.
                            • jasonflippin
                              • Jan 2014
                              • 52
                              Where would I find other potential adjustments I could make to see if it would help?
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                This is sounding more like a problem with the Asus you repaired. Might want.to find out the waveform coming from the sis with an oscilloscope if possible. Since you have the service manual.
                                • jasonflippin
                                  • Jan 2014
                                  • 52
                                  Ok, in unchartered territory now. I do not have the service manual either but I can try to find something I suppose.
                                  Would this scope work?
                                  http://www.amazon.com/Seeedstudio-DS...4477933&sr=1-3
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Wow my spelling was horrible left there. I meant zsus. Lol. I'd hate to see you buy an oscilloscope if your only using it for that purpose. It would be cheaper to find another known working board.
                                    Did you say the screen was flickering when. You set the voltages from the power supply to the reference label on the panel?
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      What worries me.most is that you said there were pieces it fell off the board and you had to resolder them back on. were any of those pieces possibly a diode? Because if one of them were then you put it on backwards that could cause severe issue
                                      • Alastair E
                                        Chief Womble
                                        • Mar 2013
                                        • 1963
                                        • U.K.
                                        #79
                                        From experience with the V6, the IPM temperature after 10 minutes in a coolish room is just barely warm.
                                        After an hour or two, it'll pretty warm--but not burning hot, easy to keep hand on it, prob around 40 deg C
                                        I have a skeletonised V6 at work on the end of the bench as a sort of exhibit. Its not got a great panel--has green dot syndrome, but its just for decoration more than anything.
                                        (Plus I get to watch telly at work!)
                                        I repaired another set, a Goodmans with the V6 panel, that had a shot X-SUS IPM, no picture at all, blown Vs fuse...
                                        The same sort of temperature range was observed when I replaced the IPM and got that one working.
                                        The IPM on Y-SUS gets a bit hotter than on X-SUS--then again its a bigger part anyway, but neither should be too hot to touch after an hour...
                                        --I did replace all the 33 and 68uF caps around the three 15V regulators on the Y-SUS of both sets, these 15V rails supply amongst other things the IPM switching drive voltage and if low can cause the IPM to get hot/fail.....
                                        --There's only 6 of 'em and easy to change, might as well do them, Use 100uF 35 or 50V to replace the hideous S.M. ones the makers used.....
                                        TELEFIX
                                        • jasonflippin
                                          • Jan 2014
                                          • 52
                                          Yeah, when the voltage was set it was somewhat pixelated. When turned down it was quite a bit better. I will take a picture of the pieces that fell out but I am certain I have them back in right as the old board I bought from ebay the guy didn't want back and just let me keep it so I was able to use it for a comparison.
                                          I'm not too worried about buying the oscilloscope. I know this TV isn't worth much but, in a weird way I think this is kind of fun trying to learn something new. But, I worry I am going to annoy you all asking questions, hopefully that doesnt happen
                                          Alastair - I will look at replacing those caps. Only thing i can think from a heat perspective then would be that I didn't get enough of the heat compound spread around. I may try to figure out how to pop that heat sink off to look at that as well.
                                          • starmaxpc
                                            LG 50ps60 Plasma Grainy/Fuzzy Horizontal
                                            by starmaxpc
                                            hi fellas. i picked a freebie locally it is a lg 50 inch plasma with display issue. tv turns on i can navigate thru the side button controls volume is good channel up down etc. looking thru the other postings on this system there seems to be a variance of different issues with this model. any direction as what would cause this display issue. sorry my pics are sideways as i don't have the stand and the darn thing weighs a ton. Thanks....
                                            02-27-2021, 07:10 PM
                                          • bk304
                                            Trouble reading BIOS on Dell Precision 3571
                                            by bk304
                                            I am trying to read the BIOS chip installed in a Dell Precision 3571 so I can remove the administrator password. Processor is a 12th gen i7. The service tag ID is 7QV7VL3 (8FC8).
                                            So far, I have not been able to read the chip. I have done this a few times on older 8FC8 BIOS chips and have not had a problem. The BIOS chip is an XMC XM25QH256CXIQ (U2502 marked on the board). I am using a T48 (TL866-3G) programmer and a pogo pin probe for the WSON8 chip. The programmer auto ID is identifying the chip correctly but the ID check comes up FF FF FF. It should be 20 40 19. Pin detect is OK....
                                            08-17-2025, 11:51 AM
                                          • SuperAman
                                            PS5 HDMI port diode reading?
                                            by SuperAman
                                            I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                            02-03-2024, 10:16 PM
                                          • TURSTY
                                            Replacement IGBT's for LG TV reading weird
                                            by TURSTY
                                            Hi guys,
                                            I have a LG Plasma that went bang one night.
                                            Long story short, I took it to a "professional" shop to repair the YSUS board that was shorted and they did a half ass job.
                                            I'm a long way down the path of teaching myself component level repair, but not 100% confident in everything yet, hence what might be a basic question.
                                            The repair shop replaced 3 transistors on one of the two heat sinks and fixed one short, but the second set of transistors on the second sink still had a short.
                                            So I removed this sink...
                                            08-01-2023, 07:38 PM
                                          • trex66
                                            Craftsman 82345 Multimeter broke!
                                            by trex66
                                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                            03-04-2025, 04:26 PM
