Hi all!
First off I want to thank anyone in advance for any advice you may able to provide me. I have taken up the challenge of fixing an issue I am having with my Sony Bravia and have read numerous forum responses on similar issues for other users. The Model number is KDL-46XBR4 and was manufactured in 2007.
I will start with the symptoms I am having:
-TV starts up sometimes and everything seems perfectly fine. It does not shut off or do anything out of the ordinary. But other times when you try to turn the tv on the green light turns on but there is no screen, sounds, or back light. I also get the standby light that flashes 5 times. The more the TV has been turned on and warmed up the harder it becomes to start the tv up.
-I have found two badly damaged SMD capacitors on the Main Board (AU board part# A-1362-637-A) I will attach these images including the location of these capacitors on the board.
I really have two questions:
- I know I have read many and many forums about the T-Con board being the cause of this 5 blink signal by the diagnostic system, but can a damaged main board cause any malfunction that would fail to send a proper signal to the UB-1 & T-Con board? I will obviously have to fix this issue on the main board, but want to make sure I am not trial and error fixing on this thing.
- Also, based on the pictures I have provide can this board be repaired? The capacitors have leaks all over the area and my plan was to remove these capacitors and clean up the area with a cotton swab and iso-alcohol. After this is completed I was going to replace to two SMD capacitors (47uf 16v & 10uf 16v) with the same rated capacitor, but with leads on it and just bend the feet to fit on the surface mounted circuit board. I was hoping to try this method instead of purchasing a used board off ebay (which is only about $25) so I can learn how to repair such items and to save as much money as possible.
I have read about the issues of trying to replace a T-Con on this unit and am trying to make sure that I am being realistic with my expectations of this TV. I greatly appreciate any assistance any of you very helpful individuals on this site and I look forward to any knowledge you may be able to provide me!
Tony
Tony
