hi i have the above model tv witch has the 10 blinks of death it clicks and then clicks about 3 seconds later i have had a look on this site a man had the same problem he ended up changing the a board . I can not find a a board for this model any where would any other a board work with this set thanks
panasonic tx42-p42x20b
Re: panasonic tx42-p42x20b
this is the page was reading on here
https://www.badcaps.net/forum/showthread.php?t=26584Last edited by adamp91gvm; 01-05-2014, 05:53 PM.
Originally posted by adamp91gvm View Postonly white stickers say eng37f03kf and a smallone saying me-tp3
They can have white stickers with the number or a 2 letter suffix stamped on the PCB or a table printed into the board listing all the suffixes and some jumpers which indicate what suffix it is.
We have 3 sources listing an A for this model as the same including 1 UK source so it should be correct or upload some hi res shots of it top and bottom using advanced, manage attachments , max res is 2000 x 2000.
Anyway do yo have a meter to check anything?
i have the Aussie model TH-P42X20A, pretty much the same, the A board can cause SOS10, I caused mine to do it and it was the cabling was corroded and shorted out the A - SN board ribbom SN20. I fixed it by replacing the 2 buffer Ics on the A talk to the SN and the ribbon also sends 5v to the SN board, so P5v shorted tripped the SOS10 at the A.
I'd be tempted to check for shorted Vsus at either SN2 or SS11 first.Last edited by tw2005; 01-05-2014, 06:32 PM.
So several things to try.
Disconnect 3 white ribbons at A, Disconnect SN2 (SN board LHS), SS11(SS rhs) and p35(PSU , feeds the C boards bottom of panel)
Power on.
Reconnect
disconnect SS11, see if SOS10 clears.
reconnect
disconnect SN2, SN3 and Sn20
Let me know the results
edit; don't reconnect straight away due to residual voltages on P2,P11 & P35, let it stand for 5 minutes, should really check with a meter. I've spiked those bottom buffers (c boards but a Samsung) and destroyed the Ics on them which means dead panel, no repair.Last edited by tw2005; 01-05-2014, 06:10 PM.
