Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4431
    • Italy - Milan
    #121
    I tried to carry out the test but I didn't get any feedback
    We are talking a different language and i'm running out of patience, you need to be precise, WHAT EXACTLY YOU MEASURED OR FELT (HEAT etc) on the injection to the 3v line??
    • riparo
      • Jan 2024
      • 72
      • ITALY
      #122
      hi, as usual we don't understand each other, it's the translator's fault, I tried to bench test the t-con, I put a single 3.3 V power supply on the VCC3.3 point with a protected power supply, but it doesn't go into protection, then I took some refrigerant spray and sprayed it on the condenser area near the vcc3.3 point but no component heats up, I also did the test on the opposite side under the t-with no hot condenser, then I measured all the volts capacitors on the vcc3.3 line and as indicated in the photo there are those values, furthermore from the output of the diode 2179 (d6001) I have 1.60v which is the value that I find on the vcc3.3 test point, I wanted to ask you if the The problem at this point is the diode that doesn't deliver the right voltage! I hope I've explained myself
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4431
        • Italy - Milan
        #123
        Now it's better! Puff!.. Pant!..
        No shorts on the 3,3v line.. but value is low, i don't know why, the diode it"s not an output, see well, it's anode is at gnd.. the 3,3v it's probably sent on the panel, if panel has some electronics like lcd, so by injecting 3,3v to detached tcon , it is not overloaded, now connect tcon to the panel and inject 3,3v as before, if PSU goes into protection unfortunately you have bad panel..
        • riparo
          • Jan 2024
          • 72
          • ITALY
          #124
          ok Davi.p, before I perform the test with connected panel, I wanted to remove a doubt, if I insert the 3.3v externally do not go to overcome the necessary voltage? since the test point already comes 1.60, should the voltage to be applied not be lower? i don't know if I've explained myself well
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4431
            • Italy - Milan
            #125
            The test is to be made only with external 3,3v not the internal PSB of TV...
            • riparo
              • Jan 2024
              • 72
              • ITALY
              #126
              i thank Davi.p for the great help he gave me to check the panel, unfortunately the panel is defective I will store the power as spare parts
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4431
                • Italy - Milan
                #127
                How can you know it exactly? This is misterious
                • riparo
                  • Jan 2024
                  • 72
                  • ITALY
                  #128
                  i recovered from another TV all the cards, main board, power supply, T-con is I mounted it on my TV, the same flaw, the panel went, thanks Davi.p
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4431
                    • Italy - Milan
                    #129
                    ok, do you have tested your boards on the donor tv?
                    • riparo
                      • Jan 2024
                      • 72
                      • ITALY
                      #130
                      yes, I did this test too, it's the panel of the other TV turned on without problems
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4431
                        • Italy - Milan
                        #131
                        Now you sell the boards.. From where are you?
                        • Donny2derby
                          • Apr 2023
                          • 228
                          • Uk
                          #132
                          So Davi……after going round all the houses and telling the guy to do loads of random tests….. Turns out Diah is correct and the panel is fried!
                          I don’t understand how you can criticise him!
                          Funny!
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4431
                            • Italy - Milan
                            #133
                            Donny2derby: thank of you i have read back all posts of diah losing time, he never said bad panel, he said my tests fried the tv but the tv is in the same state of the begin, if you are not technical prepared to understand don't bother me, and take your dear Diah, don't create further polemic, there was enough in this thread..
                            • Donny2derby
                              • Apr 2023
                              • 228
                              • Uk
                              #134
                              Davi I didn’t say that Diah said your tests fried the set. I said he diagnosed the set as being fried a long time ago. So all tests you told Riparo to carry out after that were completely pointless and wasted a lot of his time.
                              Diah is master of telly repair. You should try and learn from him too not fight with him.
                              • riparo
                                • Jan 2024
                                • 72
                                • ITALY
                                #135
                                however I break a spear in favor of Davi.p , if it wasn't for him I would not have had the opportunity to understand the problem, I was lucky to find my own TV friend to try in the definitive way TV, I thank everyone for the collaboration and especially to Davi.p for the patience I had in relation to me.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4431
                                  • Italy - Milan
                                  #136
                                  donny2derrby you don't know what you say, i've read so many rookie things by the user Diah that i'm sure i have no things to learn by him, by my side i have not ever put my hands on a OLED so i cannot be a master, i do my best to learn something but not from him, to be clear, the oled are similar to lcd, when there's a bad panel some attempts could be made, as we save lcd with bad panel we can save oled.. with the luck.. the Panasonic manual is very poor, what do you want from me? The dear Diah have said another thing, he said "i have toasted the tv", i cannot tell the right words to define him because of the rules of the forum.. now stop polemics!
                                    ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                    This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                    09-07-2024, 04:30 AM
                                  • FZG
                                    Panasonic AG-1000B VHS player with bad picture quality
                                    by FZG
                                    Hello!
                                    I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                    Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                    I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                    Also, what mechanism is this?
                                    Any feedback is appreciated!...
                                    05-06-2024, 07:16 AM
                                  • pingaroon
                                    Panasonic TX-37LXD85 blinking LED no picture
                                    by pingaroon
                                    Just so you know, I have zero knowledge or experience of fixing TVs - I'm a laptop repair guy, who can do board repair, so hopefully you guys can guide me how to determine where the fault may lie.
                                    So, TV has worked perfectly for years. Watching it tonight, the screen suddenly switches itself off and there is a red LED which blinks every few seconds forever. It doesn't blink a certain number of times, it just blinks on and on until the TV is manually powered off
                                    Powering off the TV, and back on, the LED goes green and the sound from a roof aerial...
                                    01-27-2022, 02:01 PM
                                    Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                    This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                    09-07-2024, 07:12 AM
                                    Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                    This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
