Panasonic TC-P42S30 issues
+ More Options
Posts
  • Ccalxr
    • Oct 2012
    • 33
    • U.S.
    Hi guys. I have a tc-p42s30 with a little bit of a different issue than I have been able to find with anyone else. The tv will power on normally, no blink codes. The panel lights up with large horizontal bars filled filled with think vertical lines. The audio will come one. I figure that the SN board (tnpa5349) is the culprit and like others I'm having a difficult time finding a new SN board. After doing some research it appears that some people have had success replacing the IC chips on SN board. I'd rather just replace the board but right now its not looking like much of an option. My issue is I really do not know how to test the chips to see which ones are bad. I can replace them myself, just need to find out which ones are bad. Can anyone tell me how to test these chips? I have attached a pic of the panel so you can see what I'm talking about and I also provided a link to a "repair kit" for this board. Please let me know if you have any insight for me here. I would GREATLY appreciate it.
    http://www.ebay.com/itm/PANASONIC-TN...item2eccec8344
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P42S30 issues
    To put it simply, they short out . If you have a meter that has continuity or diode mode, set to that and any continuous beep will be a dead one. Could also measure resistance, pick any 2 pins, usually shorted across all 3 but try all combinations of the of pins to be sure .
    Can you still access the other post and maybe delete the content? I just posted there, I'm going to edit it referring to this duplicate.
    • Ccalxr
      • Oct 2012
      • 33
      • U.S.
      thanks. for some reason my original post will not allow me to edit or delete. I tried. If you can delete it that'd be great, thanks and sorry.
      • tw2005
        • Oct 2011
        • 6458
        I'm just a user, just like you. It'd be admin job but I've never figured out how to contact admin when I've had a problem.
          I'd check -Vad and Vsc voltages on SN board.
          • Ccalxr
            • Oct 2012
            • 33
            • U.S.
            sorry i dont really know exactly how to do that and i have an analog multimeter, im not sure if that makes a difference. my plan so far is to replace the mosfet and ic chips at Q401 Q402 Q421 Q422 Q441 D401 D421
            IC502 AND Q53. from what ive read this should take care of it unless something more major. I tried to take some reading with my multimeter on the different mosfets and each give me a different reading but I really dont know which ones are bad and which are ok.
            • Porky1
              • Jan 2014
              • 10
              I'm experiencing a problem with the same set. I traced it down to the SN (some call it SC) board and find a short to ground on it's power connection. The boards are nowhere to be found so I am going to attempt a board level repair. Had the same questions about how to check the mosfets. Does anyone know if you can check them with them installed on the board or do they have to be removed?
              • Porky1
                • Jan 2014
                • 10
                One other question is whether you found a source for these parts. If you have, I would appreciate it if you would forward the location.
                Tx
                • Ccalxr
                  • Oct 2012
                  • 33
                  • U.S.
                  porky, so far this is the most complete "repair kit" i have found. there are others but they arent as complete.
                  http://www.ebay.com/itm/PANASONIC-TN...item232ffaec1b
                  • Porky1
                    • Jan 2014
                    • 10
                    Thanks I have an email into them to confirm the application of their kit to my problem.
                    • tw2005
                      • Oct 2011
                      • 6458
                      They fail short cct so you could test them in cct as a quick guide however quite often they will be in 2 or 3s in cct so one bad one will short the others but when removed you sometimes may find not all are shorted.
                      • Ccalxr
                        • Oct 2012
                        • 33
                        • U.S.
                        well i got lucky and found a refurb board cheap. going to just swap the board and keep this one for a project later.
                        • SCITOMMY
                          • Dec 2013
                          • 35
                          • US
                          Wait. I have the same exact TV. I ultimately had (4) shorted mosfets on the SN board, which caused the TV to not show a picture at all and give a 7 blink code. On these TV's, if there is a short circuit on any board, the Power Supply will shut down automatically and give a blink code to prevent further damage.
                          It's odd to me that yours would powered up normally if it was a shorted component(s) on the SN board.
                          • Ccalxr
                            • Oct 2012
                            • 33
                            • U.S.
                            yes i agree. i have not been able to find anyone else with a problem similar to mine, but its the only think i can think of. all pany's are supposed to throw a blink code when any board shorts, even the panel. this is bizarre.
                            • SCITOMMY
                              • Dec 2013
                              • 35
                              • US
                              If your still getting a picture at all and the TV is running without a blinking code, then you should definitely not have a shorted component. On this model anyway.
                              Do you have anything hooked up to the TV at all?
                              • Ccalxr
                                • Oct 2012
                                • 33
                                • U.S.
                                no but when i have the cable box hooked up, i get sound. like i said, ive never dealt with a panasonic plasma that behaved like this. i thought a board at first but even a faulty a board will trigger a blink
                                • SCITOMMY
                                  • Dec 2013
                                  • 35
                                  • US
                                  Yeah, I think you should be getting some kind of blinking code if it was a component on a board problem.
                                  Have you tried reseating the ribbon cables that go from the panel to the SN board? You can try taking out the ribbon cable(s) and reseating them (where the problem is on the screen)
                                  (Make sure you power down the TV first or you will short something out on the SN board if you do this with it powered up (like I did).
                                  • Ccalxr
                                    • Oct 2012
                                    • 33
                                    • U.S.
                                    i tried that. same result. i wonder if there could be an issue with the a-board as well since its not producing a blink code.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      do you have a manual? try service mode, then you can either try test patterns or I'd be tempted to try the mirror option and flip the display vertically and see if top goes black and bottom has that messed up display.
                                      on these a dead short on the Vsus at power up does not produce a blink but a solid led.
                                      It is possible to have a fault yet no codes as well, I've managed to create that situation on my TV.
                                      section 6 are the instructions.
                                      • SCITOMMY
                                        • Dec 2013
                                        • 35
                                        • US
                                        Can you turn the TV off and on with the remote?
                                        Have you tried holding down the power button for 10 seconds on the TV? Any blink code after that?
                                        My next step would be pull out the P2 and P11 connectors on the Power Supply, power up the TV and see if you get a blinking light.
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • HKS00
                                          Panasonic CF-20 Track pad issues
                                          by HKS00
                                          Hello Everyone,
                                          My name is Haris and, I am new to the forum. I would appreciate any help I can get.
                                          Little back story on me and the issues that we are dealing with...
                                          I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
                                          03-08-2023, 10:34 AM
                                        • newgen2005
                                          Panasonic DMR-ES30V power issues
                                          by newgen2005
                                          I picked up a Panasonic DMR-ES30V (UK). When I first plugged in there was nothing, appeared completely dead, I then turned it on and off a couple of times at the mains supply and it came on. It accepts a cassette but then spits it out straight away, the DVD drive functions sometimes but then the unit turns off with nothing on the display. I took the back off and noticed the fan does not spin. The display for the DVD side does seem a little dim when it is working.
                                          I have looked on google and people say it is most likely a capacitor/s.
                                          Just looking for some advice on which...
                                          09-26-2024, 03:49 AM
                                        • gre0013
                                          Panasonic TC-59R62 Overscan issues. How to adjust?
                                          by gre0013
                                          Hello. I need help opening the service menu on a Panasonic TC-59R62
                                          Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
                                          Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
                                          07-26-2024, 10:14 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                          11-20-2024, 08:52 PM
