Samsung LN40C500F3FXZA Power on issue
  • whatusername
    • Dec 2013
    • 456
    Picked up this 40" Samsung on Cl was told red light is on but TV will not come on he said he was told main board.. I opened it up Caps look Good i plug it in red light is on but will not power on as he stated.Once i unplug the main board the back lights light up and the screen is blue.Plug in main board and it wont power up.. it would seem pretty cut & dry its a main board issue but i know with TV's anything is possible so i ask the input of More knowledgeable Men
    here are some pics
    Re: Samsung LN40C500F3FXZA Power on issue
    Any reaction on Power LED from pressing buttons? How does it behave with T-con disconnected?
    • whatusername
      • Dec 2013
      • 456
      The wierd thing Tom is i do not see any buttons on this TV unless its has a Touch Sensor. but i tried to press on the front where the butons should be and nothing happens i will remove t-con now. BRB
      T con unplugged and it is still the same
        It does have touch buttons, built into frame. Confusing but they are there.
        • whatusername
          • Dec 2013
          • 456
          ok well tcon is not connected and it is still the same
            Pretty much confirms main board is at fault. I don't yet know if anyone has been successful at repairing these main boards.
            • whatusername
              • Dec 2013
              • 456
              I figured as much.. I would love to learn to repair boards VS having to replace them all the time.. It would save so much money. Any tests i can try with only a DVOM?
                Voltage regulators -- https://www.badcaps.net/forum/showthread.php?t=22231
                • whatusername
                  • Dec 2013
                  • 456
                  ok i will read through that but Tom i took off the main board and looked it over with a magnifying glass and i saw this... what do u make of it? VT-803
                    Hmm, yeah, that looks bad. Does that component test as open?
                    • whatusername
                      • Dec 2013
                      • 456
                      i will check now... what am i looking for ohm or continuity?
                        Ohm -- report reading.
                        Continuity just says if value is below a certain figure.
                        • whatusername
                          • Dec 2013
                          • 456
                          ok well on ohm VT803 shows 0.00
                          D803 which i believe is a diode shows 122 but if i reverse the leads it shows 139
                            Any "BN##-######" number printed on PCB (not on label?)
                            • whatusername
                              • Dec 2013
                              • 456
                              Bn41-01181c
                                Can't find any schematic unfortunately. Trying to find parts list, found one for 40" LED Cxxxx series but unfortunately it is a different main board.
                                • whatusername
                                  • Dec 2013
                                  • 456
                                  yea im also searching
                                  • whatusername
                                    • Dec 2013
                                    • 456
                                    ok what exactly are we trying to find out? maybe i can message a seller on ebay and they will tell me the info? i worked once before for me
                                      Description of what those parts are.
                                      • whatusername
                                        • Dec 2013
                                        • 456
                                        i cannot find anything not even a chassis number lol this is frustrating. i guess i will just have to order another board
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
