Insignia NS-LCD19-09 (PS OK, Inverter problem?)
  • valvashon
    • Oct 2020
    • 91
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up properly. The measured resistance value across the +12 and ground of the inverter circuit is approximately 5 ohms which can't be correct.
    See attached, I traced out the circuit and the only logical place for the resistance to drop to that level is across one or both of the inverter MOSFET's, Q805 and Q806 if one or both are shorted internally. C811 and C812 are both good and have been removed. With these out the resistance is still about 5 ohms. +12 is highlighted in yellow and ground is in red. As you can see the only place they could meet up with such low resistance is Q805 and Q806, unless C801 or C802 and IC801 somehow became shorted.
    Thoughts on replacing the MOSFET's? Anything else I could test to confirm that they are bad? If only one is bad and I pulled it out of the circuit should the +12 rail come back up and light up the other MOSFET, thereby lighting up half of the screen?
    Val Click image for larger version
  • mon2
    • Dec 2019
    • 14546
    To test a mosfet, remove all power. Wait a while to allow for the capacitors to discharge. Meter in resistance mode.
    check the resistance across each mosfet:
    source & drain
    source & gate
    gate & drain
    checking for a low resistance which will mean the mosfet is defective. Post each measurement.
    • valvashon
      • Oct 2020
      • 91
      source & drain
      source & gate
      gate & drain
      Mosfet # 1 2 3 4
      Source & drain 4.4 ohm 0 ohm 4.4 ohm .3 ohm
      Source & gate 222 ohm 104 ohm 7.0 m ohm 5.2 k ohm
      Gate & drain 227 ohm 104 ohm 5.4 m ohm 5.2 k ohm
      These are some all over the place resistance readings. The short and almost dead shorts tell me I broasted some FET's during the "incident". The schematic and specs call for the FET's to be "AM4502C-T1-PF" with 11 amps maximum N-channel continuous drain current but the actual ones on the board are FDS8958A FET's with 7 amps maximum continuous drain current.
      I think I found the AM450 type on aliexpress so I'll be ordering some of those.
      Val
      • valvashon
        • Oct 2020
        • 91
        Replaced the shorted MOSFET's with eBay specials from across the ocean. Marked FDS8958A, they could of course be counterfeit but as you can see, the TV now works. Would love to now thank everybody for their help but of course the saga continues. The set will turn on and come up with a picture, but then turn off after 5-10 seconds. Subsequent turn on's will produce a flash of a screen, then turn off again. It takes 4-5 tries to actually get it to turn on and stay on. When it does it will stay on all day. This was before I put my auto turn-on circuit into the equation. Now, instead of having to turn it on manually it will auto restart but exhibit the same behavior- on-off-on-off, etc., various lengths of on time before it turns back off again. Once the TV is up and running you can turn it off and on manually and it works as it should.
        I do get a series of red blinks when it powers up (this was the case before, too) and now get red blinks as it shuts off which may be normal but I don't remember this. Am I looking at something weak in the power supply (like a cap) or knockoff MOSFET's that can't handle the job of finishing the power-up? Tomorrow morning I will pull the wires from one of the backlights and see if that affects the startup.
        I could always try to obtain the specified MOSFET's with their higher current handling capabilites.
        Any ideas welcome. I can make a video of what it's doing if it will help.
          • 12229
          • U.S.
          Might just be the problem, you don't want to use ones with a lower current rating.
          • valvashon
            • Oct 2020
            • 91
            The FET's are marked the same as the ones that came out of there although of course they could be counterfeit. Digikey shows this part number as a "last time buy" starting in 6/2024 so fakes could already be popping up. Schematic shows the higher current ones but the lower current ones were on the board before I started shorting things out.
            The set would power up and stay powered up (the first time on startup) when I had one or the other backlight connectors pulled. Dim screen during startup but then it went black. Could still hear audio; I assume that the screen going back with one backlight out is normal.
            Monday morning I will warm up the power supply with a heat gun to see if that allows it to start. I still think it might be a power supply issue. The set restarted 20-30 times this morning, gradually staying on longer but never actually staying on. That's making me think it's a PS warm up issue.
            • diif
              • Feb 2014
              • 6978
              • England
              If the set is giving a picture that suggests the MOSFETs are fine.
              If heating the boaerd has an effect then I suspect it's the caps, but i don't think it will and it's tired CCFLs
                • 12229
                • U.S.
                Be careful not to overheat with a heatgun, I just use a hairdryer it's plenty hot enough to find a marginal/faulty cap.
                • cind12
                  GTX 1080 TI Gigabyte Aorus low resistance on vmem
                  by cind12
                  Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                  Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                  The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                  Resistance on 12V 4K ohms (Power present when on)
                  Resistance on 12V PEX 4K ohms...
                  12-08-2023, 09:09 AM
                • Nagy Daniel
                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                  by Nagy Daniel
                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                  So, I generated a table with AI so I can...
                  03-04-2025, 08:24 AM
                • x_orange90_x
                  by x_orange90_x
                  01-29-2025, 09:24 PM
                • Gentian
                  APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                  by Gentian
                  I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                  It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                  03-06-2023, 07:07 AM
                • eccerr0r
                  A modified sine wave inverter + a grid tie inverter?
                  by eccerr0r
                  If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                  Next thing is trying to charge the batteries using solar power, but that's another issue ...
                  08-31-2023, 09:14 PM
