Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
Vizio D50u-D1 Dead Set No Standby
  • fharris1977
    • May 2017
    • 132
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
  • EazyBone
    • Jun 2023
    • 1419
    • United states
    • Anything I can do with my hands
    Check for any shorts on mosfets, or bulging caps first. You say you see 5v pins, but do they have any voltage to them? Bit confusing. It's likely you should be looking at PSU if you have zero voltages except .50
      • 12370
      • U.S.
      Check all the solder joints on bottom of powerboard, examples of bad joints there: https://www.google.com/search?client...h=544&dpr=1.09
      • tvguy12012012120
        by tvguy12012012120
        02-07-2025, 05:13 PM
      • piposarcade
        Samsung UN50KU6300 dead no standby led
        by piposarcade
        01-04-2024, 01:33 PM
        Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
        05-22-2024, 02:07 PM
      • xbliu.cn@gmail.com
        ASUS ROG Zephyrus G14 GA402R – 19V present but no 3.3V/5V standby, no power
        by xbliu.cn@gmail.com
        I’m looking for help diagnosing a no-power issue on an ASUS ROG Zephyrus G14 (GA402R / GA402RK series). ā— Problem
        The laptop does not power on at all:
        • No LEDs
        • No fan spin
        • No response to power button
        The issue started right after a RAM upgrade. The previous owner mentioned there may have been static discharge during reassembly.
        šŸ” What I have checked so far (with a multimeter)
        • AC adapter is confirmed working
        • 19–20V is present at the DC jack
        • Both input MOSFETs have 19–20V on both sides
        • Multiple inductors near the eDP connector
        12-13-2025, 11:40 PM
      • jacobtc
        LG C1 65'' dead standby
        by jacobtc
        I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
        If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
        If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
        I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
        01-29-2025, 04:27 AM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
