Bn41-00813b
  • jpalmeida
    • May 2008
    • 11
    Bn41-00813b
    Here are the picture of the IC1107 & IC1106 1117 07135L.
    May anyone identify the manufacturer logo?!
    This two regulators ICs seemed to be heated, the metal base are a bit blue.
    Last edited by jpalmeida; 01-01-2014, 10:48 AM. Reason: Can't see the uploaded pictures
  • jpalmeida
    • May 2008
    • 11
    Re: Bn41-00813b
    Here is the photo.
      Re: Bn41-00813b
      Could be Alpha&Omega Semiconductor.
      Though exact manufacturer isn't important: 1117 (LM1117/LD1117/TC1117) are standard parts, all more or less the same as each other.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Bn41-00813b
        agree not important.
        not found much on cac.
        not alpha & omega though
        • selldoor
          Slow Learner
          • 7870
          Re: Bn41-00813b
          It is an anachip
          http://pdf1.alldatasheet.com/datashe...P1117-1.5.html
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • yuii
            ThinkPad W530 - faulty CPU regulators?
            by yuii
            Hello
            I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
            Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
            The latter is completely dead and has the same 2-second power blink, nevermind...
            11-01-2023, 02:59 AM
          • silver60618
            How to clean Liquid Metal from under CPU?
            by silver60618
            Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
            The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
            Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
            07-11-2025, 01:47 PM
          • shadow666
            ASUS N43SM with Nvidia GT620M crash after touch metal case
            by shadow666
            i have a asus N43SM i7 2th gen and i have a big probelm
            After hitting the metal part of the touchpad or the sides of the mouse is metal, the system locks and the image crashes !
            disassemble notebook and this cover on top picture I insulated all the bases on which the screw is fastened so that static electricity does not cause this problem again but not working !
            Sometimes, when I didn't work with the notebook for a few minutes, after I touch the touchpad, the image confused​ and the system locks ( See Down Picture). I have to turn the system...
            01-05-2025, 08:45 AM
          • seweryn
            Dell 2007FPb with 4 buck step-down regulators
            by seweryn
            I have monitor Dell 2007FPb. It was working good. Some day it was shut off and stay dead.
            I checked some voltages on the boards. I read this thread:
            https://www.badcaps.net/forum/showthread.php?p=335335
            and very usefull budm posts ( thanks buddy, it was great work ... ).
            My damage was typical: 3A fuse burned and ZD701 diode was shorten.
            So my board is in few points different than other described in citing thread. On my board are 4 buck converter regulators. Apart regulators 3.3V (Q6), 5V (Q14), 12V (Q9), is ther fourth, build on MOSFET Q2. Two TL1451 has together...
            04-08-2022, 11:43 AM
