Tv Sharp lc-40ld270e
  • Amazig
    • Jul 2021
    • 10
    • Portugal
    Hello everyone, I have this SHarp TV model lc40ld270e, I have it in storage for some time; When I turned it back on, it initially had a bluish screen, I replaced the LED strips and the image returned to normal, but it appears that there is something else worse; it turns off and on by itself; and the message that is in the attachment appeared, if anyone can help I would appreciate any idea or help, thank you
    • 12323
    • U.S.
    A factory reset might get you up and running again.
    • Amazig
      Amazig commented
      Editing a comment
      Hello, I have already done a factory reset and the problem continues, thank you for your contribution
  • cheeky2
    • Dec 2012
    • 339
    A question do you have any cards plugged into the PCMCIA type slot as this may possibly be causing the issue, that could be used for satellite or pay per view. Remove the card if you have one plugged into it. See attached picture for the reference to the connection.
    • Amazig
      Amazig commented
      Editing a comment
      Hi, the TV never had any card, it always worked with a telecommunications operator box, thanks for your contribution
  • Amazig
    • Jul 2021
    • 10
    • Portugal
    Happy New Year everyone, I need your help; power supply: 715g6795-p01-000-002h I need a service manual, thank you for your help
    thanks​
    note: it is the same tv lC-40LD270E
    • lotas
      • Jan 2016
      • 4905
      • Russia
      thanks​
      This diagram is a little similar to yours.
      • alltvrepairs
        Sharp LC-40LD270E bluish picture
        by alltvrepairs
        Have this set with bluish content even OSD. I have tried factory reset from service mode using MENU > 1999 > PRE PR
        but same.
        Main board: 715G6826-M02-000-004K
        Any help please?...
        02-04-2022, 08:19 AM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • gavenb
        Sharp LC-80LE661U 80 inch
        by gavenb
        Hi folks!
        I have a LC-80LE661U that had some interesting issues.
        Initially, it would come on and show the sharp logo and would show normal static before shutting off.
        I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
        11-12-2023, 02:05 PM
      • SONY_E-WASTER
        Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
        by SONY_E-WASTER
        Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
        The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
        then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
        does...
        12-26-2021, 05:46 PM
