TH-42PX80U & TC-P42X1 Panny Panasonic
  • apetay
    • Dec 2013
    • 24
    Photos are from TH-42PX80U Feb of 2008, and I can't figure out which number is the part number. Sorry I'm new at this.
    I'm wondering if they were still using the same plasma panel and glass in June of 09 in the TC-P42X1. If not, then it will save me a trip.
    It looks essentially the same from what I could find on the net.
    If anyone has detailed information on how parts get numbered, I'm all ears.
    3 repairs under my belt, 3 repairs in progress
  • tw2005
    • Oct 2011
    • 6458
    Re: TH-42PX80U & TC-P42X1 Panny Panasonic
    MC106H30T11, 42"= 106.68cm, hence the 106.
    The X1 should be MC106H30U12.
    Is this going to be a panel swap?
    SJ website is real handy for this kind of research.
    It may be feasible, the buffer boards although different numbers appear to have the same profile. The key difference are the connectors used between the SC and SD/SU but apart from that should bolt in and match the ribbons. The newer model looks like there's some holes for plastic stand-offs.
    The SC boards are matched to the PDP characteristics but I'm not an engineer.
    Will the SC board mounts line up? that's worth looking at, at a glance it may just
    What exactly are you trying to achieve? is the 2009 panel going into 2008 or vice versa?
    If it was dirt cheap, might be worth the gamble.
      I don't think it'll work... X1's panel will have a different gas mix, it's not compatible. It's a more efficient panel. 2007->2008, and 2009->2010 maybe, but not 2008->2009.
      • kenny1070
        • Oct 2013
        • 65
        Don't know if this helps but:
        TH-42PX80U (gph11du) = panel # MD42H11A1J
        TC-P42X1 (gph12du) = panel # MD42H12A2J
        According to TVservice Parts there are no replacements available for either, which I would guess would mean they are non-compatible.
        http://www.tvserviceparts.com/MD42H11A1J.html
        http://www.tvserviceparts.com/MD42H12A2J.html
          Who the hell charges $1500 for a plasma panel from a 6 year old, 42" 720p set?!
          • kenny1070
            • Oct 2013
            • 65
            Couldn't agree more.
            I simply posted this as reference material only.
            • tw2005
              • Oct 2011
              • 6458
              That is a valid point, you'll probably have issues with voltage levels.
              PX80
              Vset TPVSET
              (SC)
              320V ± 7V Fixed
              Vad TPVAD (SC) -149V ± 1V VR16600
              (SC)
              Vscn TPVSCN
              (SC)
              Vad+145V ± 4V Fixed
              Vda TPVDA (SS) 75V + 1V, -2V Fixed
              X1
              Vset TPVSET
              (SC)
              290V ± 9V Fixed
              Vad TPVAD (SC) -180V ± 1V VR16600
              (SC)
              Vscn TPVSCN
              (SC)
              Vad + 145V ± 4V Fixed
              Vda TPVDA (P) 60V + 1V, - 2V Fixed
              Front glass PX80, TKGA5426S
              Front glass X1, TKGA5541S
              • apetay
                • Dec 2013
                • 24
                This indeed was going to be an attempt at swapping the working 42PX80U panel into the TC-P42X1 with glass damaged in transit, but now I know it won't be worth the trip. Thanks for the help folks! So on to my plan B...
                Can I swap these? They are obviously not the same part and rated a little differently but they do the same thing, essentially, right?
                852318 is the one that I am suspicious is at fault for blowing the fuses on the power supply (LSJB1260-1 AN), and 852085 is tested working (harvested from a Toshiba 42HP95 w/ PSC1013IF M).
                I promise after this stab at it in the dark, I will get a decent multimeter.
                I'm so broke right now I can't even pay attention!
                Last edited by apetay; 01-01-2014, 10:01 PM. Reason: Photo did not upload, poor grammar edit, added info
                • apetay
                  • Dec 2013
                  • 24
                  It appears that if it would work, I would have to reverse the wire harness pins or female quick slides. I can guess which one's easier.
                  I think I got the model numbers wrong... It's GL-2080FVP-L in replacement of GL-2080FVP-XLW. Every time I plug into the original filter, it immediately fries the fuses on the PS so I've grown suspicious of the filter. Maybe I'm barking up the wrong tree, but regardless, I sourced this replacement part for free, so if I can use it, great, if I can't, so be it.
                  I'm so broke I still can't pay attention.
                  • apetay
                    • Dec 2013
                    • 24
                    1500 does seem ridiculous, however I've got one up on craigslist for $20.00. Is this asking too much? It's not like there were other ones up to compare it to.
                    I'm sure if it was hooked to a better A board, it would be a fine part.
                      Panel, or TV? Panel alone at most 30% of TV value due to installation cost. TV around 60~75% of retail value.
                      • apetay
                        • Dec 2013
                        • 24
                        Just panel from 2005
                          $20 is quite low for a panel, but most people don't bother replacing panels these days.
                          • apetay
                            • Dec 2013
                            • 24
                            This is exactly the kind of general information I was looking for, and it seems the hardest to track down on the net. I guess if I had been paying attention to this kind of stuff for the past 10 years, I'd already be caught up. I've decided to really motivate on metal conservation, and e-waste elimination. There's plenty of 'junk' displays out there, so finding them's the easy part. I've found a service manual or two, and a 42" they didn't make a service manual for, which I found very irresponsible (of the industry). Plus I really love poking around in display technology.
                            • apetay
                              • Dec 2013
                              • 24
                              Cool, it's priced to sell. Maybe I'm a bit masochistic, but I think swapping panels is fun.
                              • Andre Gilbert
                                by Andre Gilbert
                                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                11-20-2024, 08:52 PM
                              • tongshadow
                                Panasonic Plasma 2008 TH-42PV/PX series - Removing the coating from the Front Glass
                                by tongshadow
                                I got this set for very cheap, it works perfectly but the catch is that the protective coating was damaged. About 45% of the screen had a green tint, you can see exactly where the layer changed colors to a blueish tone (that actually makes everything green).
                                "Ok, that's probably just the anti-glare layer" - I thought. So using a microfiber cloth and automotive metal polish I was easily able to turn it into a nice mirror.
                                Unfortunately, the damage was beyond this layer and everything still had a horrible green tint. I initially...
                                03-12-2023, 12:06 PM
                              • AquaMan Ua
                                by AquaMan Ua
                                05-17-2025, 09:40 AM
                              • stecos
                                Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                by stecos
                                Hi everyone!
                                For my passion for technology I'm now collecting several...
                                11-28-2022, 11:39 AM
                              • aa10aa10
                                Panasonic Toughbook CF-33 mk1 BIOS repair
                                by aa10aa10
                                Good day,
                                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                01-21-2025, 06:13 AM
