LG OLED 55EG9100: is this screen damaged?
  • ivan_z
    • Oct 2023
    • 5
    Merry Christmas everyone!
    I got this TV for free, hoping that I would be able to fix it. So far I can't....
    The previous owner claimed that the screen is good, the TV has never been hit or dropped or anything like that; physically the screen does look intact.
    Symptoms:
    When I press the remote, a relay inside it clicks and a second later clicks again (refuses to power on).
    When I disconnect the black ribbon cable from the main board and the tcon board, the tv refuses to run from the remote nor from the "on" button underneath the screen, but it turns on when I press the "p-only" button on the service remote. The optical audio ports lits up. But since the tconcable is disconnected, I can't see any picture to tell if the main board works fine.
    I "forced it" to turn on by placing two jumpers (Standby3.5V toPower-On and Standby3.5V to DRV_ON); all other wires were properly connected.
    It shows garbled washed-out white image on the screen; each time I power it on the image is a bit different. See the attached files.
    In this mode I also tested the voltages on the power supply board, and I get nice 3.5 ,12 and 24 volts. So I think the power supply is good.
    So is the screen damaged or not, whatdoyouthink?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4278
    • Italy - Milan
    Disconnect main board to tcon band, place the 2 mentioned jumper plus a jumper wire from PSB 12v to tcon 12v input from main board, then turn power on, post results... my guess is bad tcon..
    • ivan_z
      • Oct 2023
      • 5
      Thanks for guiding me!
      Done. See the attachment.
      I found a 12v pad near the t-con connector on the main board, traced it to the t-con board, then hard-wired it with a jumper cable. I hope that's the same 12v as the one on the power supply board...
      The picture looks a bit different, but is still garbage.
      Also: previously at every power-on the pictured looked a bit different, now it always shows this very same picture.
      • EazyBone
        • Jun 2023
        • 1306
        • United states
        Looks like 🗑️🗑️🗑️🗑️🗑️🗑️🗑️🗑️
        Wait for diah response though. OLED man
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4278
          • Italy - Milan
          You have done a different thing, you have to test if the 12v is present at that test pad because that 12v is switched , not good for me..
          • ivan_z
            ivan_z commented
            Editing a comment
            Yes, 12v was present on that pad, and I got the garbled screen, as I already posted.
            Just in case, I wired 12v from the PSU to the 12v-input-from-the-main-board on the tcon board (as you ask), and repeated the test. The result is eactly the same: garbled screen.
            Interestingly, the garbled image appears when I connect the 12v jumper wire, and then remains on the screen even if I remove the wire.
        • Diah
          • Feb 2013
          • 6354
          this way are wrong.. lets hope you didn't dam danged he MB or the MICOM Chips...
          let every things as original connected ... only disconnect the cable of 21V between PSU and T-CON from PSU side..
          turn on ( don't use P-ONLY) if you did used this command before... need to press exit on RC first , to exit this limited operation )
          give time if its turn on ( the sign the audio Optic port lit red ) if yes....while its ON plug back the socket of 21V. give attention to the screen what will it show... or record it and show here the result
          if the set will not turn ON / this unlikely ) there other damage need to do further test
          • ivan_z
            ivan_z commented
            Editing a comment
            Diah, I can't execute your test:
            If the tcon board is connected to the main board (as you ask), the tv refuses to start: when powering it on, a relay clicks on, and a second later off.
            Same happens if the tcon board is powered (24v from the power supply) or not.
            If I disconnect the tcon board from the main board (via the black robbon cable), the tv starts up fine, but, obviously, the screen is dark.
            I also did the test that Davi.p asked, see my reply there.
        • ivan_z
          • Oct 2023
          • 5
          Update: I decided to buy a used tcon board on ebay and give it a try. It's about $40, ashipped all the way from China. Will keep you updated.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4278
            • Italy - Milan
            forgot to say you will probably have big problems of previous tv data stored on it, thus image retention, for example a chinese emitter printed firmly on screen, faded.. oled are hard bones..
            • Roncruz
              Roncruz
              • Jan 2022
              • 18
              This is my lg oled tv, it has no picture when starting it up its just showing a line in the center i got a lg service remote im pressing the p only button to get it start
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4278
                • Italy - Milan
                please post a new thread...
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • TheDando
                  MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                  by TheDando
                  Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                  10-28-2024, 06:59 PM
                • maxim2511
                  LG 55EC930V OLED - swich on swich of no screen
                  by maxim2511
                  My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                  Then I get an idea to take it apart and clean boards from dust.
                  In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                  Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                  05-14-2021, 02:21 AM
                • mrtek
                  Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                  by mrtek
                  Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                  11-26-2024, 09:58 AM
