SHARP LC-60LE635 transparent horizontal stripped
  • romasik
    • May 2022
    • 56
    • Ukraine
    Has anyone experienced this? Translucent streaks appear in the photo you can see them. They appear and disappear. Sometimes it's always streaks, sometimes it's not. If you put your finger in the area of the t-con chip, the stripes begin to appear and disappear every second. T-con to replace?
    • 12312
    • U.S.
    Make sure the cables going to and from the tcon are clean and not damaged, properly inserted and secure not loose, if you clean them be gentle, they can be delicate, can clean with ipa.
    • romasik
      • May 2022
      • 56
      • Ukraine
      Everything is fine with the cables
      • Diah
        • Feb 2013
        • 6501
        take the ribbon cable out... clean the socket and exam the clip of the sockets if they are closed tight
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4520
          • Italy - Milan
          photo is not correctly get, if you use cellular, keep it horizontal, record both clear and dark images.. are the streaks moving? does it with every input types?
          • romasik
            • May 2022
            • 56
            • Ukraine
            It doesn't matter how you hold the phone. Stripes are everywhere, there are none on a white background. It seems that the light stripes are just a slight increase in brightness. Lately they have been almost constant. There are no problems with cables. I also tried changing the capacitors on the power supply, nothing changed.
            Here's another photo
            • Diah
              • Feb 2013
              • 6501
              i cant notice the lines.. but from yours description they are NOISE .. 2 reason could be
              1- the signal source if its from Areal or Wall cable.. ( connect the TV with HDMI video source to see if the line remain ) if they remain.. then
              2_ T-CON problem
              • romasik
                • May 2022
                • 56
                • Ukraine
                I already wrote the cables are normal. There are also stripes in the TV menu. And the photo clearly shows horizontal alternating stripes
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4520
                  • Italy - Milan
                  You did not tell about using different inputs.. check if the tcon has electrolytic caps, and check them..
                  if you have no esr meter try heating them with phon and retest tv..
                  • romasik
                    • May 2022
                    • 56
                    • Ukraine
                    stripes everywhere, in the menu, on sputnik TV, at all inputs. I tried to heat the t-con board, maybe after that the stripes disappeared or maybe not, at first they appeared rarely, they might not appear for a week, but now they are almost constant . I also ordered the same t-con from China, but it broken to not work at all(
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4520
                      • Italy - Milan
                      Are there elec. caps on the tcon? Why not to change them? Before this also a reflow / resolder of tcon / panel connectors.. also try to raise the volume of audio and feel if it is present a vibrating noise, there could be a disturbing signal of some type of electric device around you or your home.. last, there could be a leakage in input filter capacitors in power supply..
                      WOW... 3333 posts... i'm going to buy a lottery ticket..
                      • romasik
                        • May 2022
                        • 56
                        • Ukraine
                        I don’t understand what the sound has to do with it, the sound is turned off on my TV, I’m using a home theater through a laptop. I changed all the capacitors except those that go to the backlight and those that are 400 volts. Maybe try a soldering iron to heat the capacitors on the board t-con?
                        • Diah
                          • Feb 2013
                          • 6501
                          i wrote in my post #7 t-con problem of this noise -- why don't show us here yours original t-con to see the main CHIPs and its Gama chip
                          • romasik
                            • May 2022
                            • 56
                            • Ukraine
                            Runtk4910tp
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4520
                              • Italy - Milan
                              I already told you about the tcon electrolytics, are you reading well what i write? The tv speakers could be a tester to catch ambient disturbations eventually.. traces of alternate voltage..
                              you tell me about electrolytics you changed, i know, i'm not dazed, i am speaking about those on the input filter, do you know? Do you have any experience in electronics? I mean polyester square types.. post a picture of power board eventually..
                              • Diah
                                • Feb 2013
                                • 6501
                                Originally posted by romasik
                                Runtk4910tp
                                T_CON with out Metal Shield cover the chips !!!!???
                                • romasik
                                  • May 2022
                                  • 56
                                  • Ukraine
                                  Yes, this is how it is installed in this model. the main board is covered with an iron shield .
                                  • romasik
                                    • May 2022
                                    • 56
                                    • Ukraine
                                    Power supply board, full image i post later, not have in my phone.
                                    • romasik
                                      • May 2022
                                      • 56
                                      • Ukraine
                                      This caps i try resolder, but nothing change
                                      • Diah
                                        • Feb 2013
                                        • 6501
                                        its T-CON issue.... packing it or try to find replacement
                                        • Strudul
                                          Sharp LC-60LE741E - Horizontal Bands / Stripes
                                          by Strudul
                                          I have a strange problem that appeared suddenly on my SHARP LC-60LE741E 60” LCD television. It has 22 evenly spaced horizontal grey stripes over the entire area of the screen. The stripes only effect dim areas of an image. Blacks are still purely black, and anything brighter than 40% is unaffected. Bright outdoor scenes are fabulous. Dark low contrast scenes ... like all CGI on Netflix are unbearable. It's like your looking through dirty venetian blinds. The grey bars appear above any slightly dark colors. If you look closely, you'll see that there are white pixels mixed in with the correct...
                                          12-20-2022, 06:06 PM
                                        • jaco2d
                                          Sharp 50bj2ke horizontal lines
                                          by jaco2d
                                          This is only my seond post and so far i am very impressed with the forums.
                                          I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                                          The small white box thing in the pics is not the tv its a reflection from the window
                                          Any suggestions...
                                          11-01-2022, 04:45 PM
                                        • Ihandyrepair
                                          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                          by Ihandyrepair
                                          Hi guys
                                          I just started fixing 4k TV few months ago. so I am still learning a lot
                                          I got this tv from friend complaint is ghosting or horizontal lines on image.
                                          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                          then it started to show the ghosting white image.
                                          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                          it has 3 thin small boards at the bottom of the...
                                          12-05-2022, 04:18 PM
                                        • kotel studios
                                          Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                          by kotel studios
                                          Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                          In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                          08-06-2025, 02:07 AM
                                        • russianbot
                                          Horizontal streaks and distorted colors on VGA output of graphics card
                                          by russianbot
                                          I have an old Geforce2 GTS that shows horizontal streaks in its VGA output, and bad colors. It basically shows gray where there should be white, and dark gray ghosting stripes across the screen from text in open windows. Also the color saturation seem wildly inconsistent. I attached a photo of how it looks.
                                          Any ideas of what can be causing this? Damaged GPU? Or maybe some discrete components on the VGA output path that I can replace? I'm trying to figure out if it's worth attempting to fix this....
                                          04-14-2020, 11:23 PM
