Hi everyone. I need your guidance in troubleshooting this TV. It is a Sanyo DP26649 with 00 chassis and N7GE main board. Service manual can be found here: http://www.tgohome.com/ServiceManual...6649&typekey=0
The green power LED does turn on and stays on until I push the power button again. The backlight never comes on. I have disconnected the 3 wire connector at K8L and the backlight does come on, but I see nothing on the screen (I pushed the buttons and no volume or channel indication appeared).
When TV is off:
5V_STBY = 5V
POWER_ON = 0V
When TV is ON (measured at K8B):
5V_STBY = 5V
POWER_ON = 5V
12V = 11.8V
5V = 5V
24V = 24V
I also measured P_FAIL and it was at 5V.
BL_ON was 0V and BL_ADJ was very low around 0.2V if I remember correctly.
Turned off the power and measured resistance across the collector and emitter of Q1751 and it was around 1.1k Ohm. I realize this is in the circuit so it may not mean much.
Any suggestions on what to do next?
When TV is off:
5V_STBY = 5V
POWER_ON = 0V
5V_STBY = 5V
POWER_ON = 5V
12V = 11.8V
5V = 5V
24V = 24V
