samsung Ps43d450a2w power board failure
    Re: samsung Ps43d450a2w power board failure
    Everyone says that!! Nearly no one tests them!
    Y-main and X-main
    • xmandarkx
      • Dec 2013
      • 54
      pics of x and y
      • xmandarkx
        • Dec 2013
        • 54
        ps-on is 0.15v is that right?
          PS ON is active low, that's fine.
          Test each highlighted. Use diode range on DMM.
          2 pin devices (diodes): test both ways, diode test. Reading of <100 = bad. Reading both ways = bad. Hold reading for 5 seconds before reading off.
          3 pin devices (FETs, IGBTs = transistors): test all pins, NO READING (i.e. "1") for all pins EXCEPT a diode reading (200~800) between two pins (drain/source) on certain devices. Reading of <100 = bad. Reading both ways = bad. Hold reading for 5 seconds before reading off.
          • xmandarkx
            • Dec 2013
            • 54
            on x board i have 2 transistors that read the same on both legs and have continuity between them and the rest give a reading of 1 and 445 or 550
            y board is the same, 2 have same reading with continuity and rest 1 and 445 or 550.
            oddly the replacement board is exactly the same, so i guess both faulty then?
              Yeah, I suspect so.
              • xmandarkx
                • Dec 2013
                • 54
                is it worth replacing the transistors or will i likely run into further problems?
                  not really worth it at the moment, boards are cheap enough -- return the board for a refund...
                  • xmandarkx
                    • Dec 2013
                    • 54
                    ok ill do that, where do you get your boards from? theres a lot on ebay that say tested but i cant trust that now
                      I got mine from parts4u.me.uk. The parts aren't tested but he sends out new boards free of charge if any are faulty. And very reasonable prices.
                      • xmandarkx
                        • Dec 2013
                        • 54
                        cheers, i will check it out. thanks for your help.
                        • keithf2
                          • Aug 2010
                          • 131
                          #32
                          Originally posted by tw2005
                          Just a thought,
                          It might be worth trying the built-in test patterns on the logic ctrl board and bypassing the mainboard..
                          Have the Tv powered off, then remove the power cable from the mainboard .
                          There should be Jumper pins 2-4 on the logic board,
                          with the power lead for the main, jumper pin 1 (PS on) to GND (pin 5). should be able to do it at the connector end with some wire or maybe a paper clip
                          plug Tv in and apply power and see if you have the same issue or if the panel comes on and test patterns.
                          You can get faulty boards supplied, they're not always tested out of broken Tvs.
                          tw2005, should the jumper be between 2 and 4 or 3 and 4 on the logic board
                          • stejones
                            • Apr 2012
                            • 55
                            • United Kingdom
                            #33
                            Hi just got one of these tvs and for some reason the picture as red and yellow in the screen can anyone help could this be a logic fault
                              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                              by sam_sam_sam
                              I was working on this CNC machine today found no keyboard functioning no control relay powering on
                              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                              Found shorted diodes on main controller relays there are 3 of them that...
                              01-07-2023, 05:43 PM
                            • Nicktronic
                              Samsung Power Supply Board BN44-00874F
                              by Nicktronic
                              Hey everyone,
                              This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                              Anybody...
                              03-17-2025, 06:20 AM
                            • Dani_2024
                              by Dani_2024
                              10-28-2024, 05:06 PM
                            • repair-it
                              Need advice testing a samsung power supply board with scope
                              by repair-it
                              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                              07-12-2025, 11:00 AM
