LG 50PK750 reflow again?
  • x_orange90_x
    • May 2015
    • 765
    A few months ago I sold my brother in law this 50PK750 that my brother repaired. The issue was with the BGA on the main board and he had reflowed it. The tv was working great up until about a week ago when the colors started going "off" and began alternating between bright and dim.
    Is this likely the BGA again, or could it be power supply related? I don't have it in my possession so I haven't had a chance to open it up yet. If it is the BGA again, is it practical to try the reflow again, or replace the main board? I found a main board for about $55, but I'm afraid of having the same issue creep up in a few months with a replacement.
  • diif
    • Feb 2014
    • 6978
    • England
    Give it another reflow before buying another board.You can also do a test with jumpers on the logic board to check if it's the motherboard giving issues.
    Buy a cheap thermometer to better monitor the reflow temperatures.
    https://www.aliexpress.com/item/1005003642882603.html
    • x_orange90_x
      • May 2015
      • 765
      I guess I never updated this post. I went ahead and did a reflow (again!) myself and the picture looked awesome afterwards. It's been a few weeks and I haven't heard any complaints so I guess it's still holding up. I heated up the chip pretty good, especially near the center. Hopefully it will last longer this time šŸ¤ž
      • diif
        • Feb 2014
        • 6978
        • England
        Did you use flux ? What about using the cheap thermometer ?
        • x_orange90_x
          • May 2015
          • 765
          No to both. My brother used liquid flux the first time, but I didn't have either of those. I did heat it to 250c for about 5 minutes going around the edges, across, and in circles.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4542
            • Italy - Milan
            Your tv buyer will come back soon claim for money back... not good reflow is been made, 250 celsius degrees are too low, you need to heaten all the board from bottom (check my posts around november 2020 on how to), then check the working state, clear well the area, then i suggest you seal the perimeter of the chip with hot glue, this is my last thought for an experiment, try if you want, if you want to be more sure also DRAM chips must get same treatment.. let me know how it will go..
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              Yea I'm not an expert but, i agree that's way too low
              • x_orange90_x
                • May 2015
                • 765
                The heat gun I had was only two settings; 250c and 400 something. I followed the advice I was given for the first reflow
                https://www.badcaps.net/forum/troubl...36#post1848336
                I'm not worried about the "buyer" because it's my mother in law's now. Initially her son bought it from me, used it for a few months, then gave it to her. I already told her if it fails again I'll just replace the board. Thankfully this is the first and only one I've repaired that has had an issue, and because of this particular incident, I won't sell a reflow to anyone again. Many people have said that reflows are a bandaid and will eventually fail again which makes complete sense because if the quality of solder was shit to begin with, reflowing won't make it "better".
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  There was nothing wrong with the quality of the solder and a decent reflow will last years. I've done plenty, and much reballing.
                  A half arsed job without flux though.
                  It's lead free and leaded solder, not shit and better.
                  • x_orange90_x
                    • May 2015
                    • 765
                    Well they fail for a reason. Regardless, we'll see how it goes. I visit frequently so I'll know if/when it fails.
                    Do keep in mind this is my own personal "first" for this type of repair. Trial and error. My brother has done this several times with monitors and game consoles. He knows what he's doing and it still didn't hold up long.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Yes, I'm well aware it was your first go, hence suggesting the thermometer. How else are you knowing what temperature the PCB is?
                      The reflow I did on a PS4 Pro two years ago is still going strong.
                      If your brother's reflows are failing short I would suggest he looks at improving his technique. Maybe he needs to follow the profile better which requires a thermometer.
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • x_orange90_x
                        LG 50pk750-ua bad main
                        by x_orange90_x
                        I just got this tv yesterday and it exhibit the exact same symptoms as the OP in the following thread:
                        https://www.badcaps.net/forum/showthread.php?t=48150
                        Power it on and the screen lights up, goes dark after about 2 seconds, and pressing any button lights up the blue led on the tv. The person in the above thread replaced their main board and it fixed the problem. I find that it's way too expensive to buy a replacement on eBay. There are "services" on eBay that claim to repair these boards, but the cost is still quite high.
                        My question is,...
                        09-20-2023, 05:57 AM
                      • Asraf Atb
                        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                        by Asraf Atb
                        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                        01-27-2025, 05:02 PM
