samsung ue55mu6192u continuous switching on and off
  • giova96
    • May 2023
    • 38
    • italia
    Hello everyone
    a few months ago I repaired this TV by replacing the motherboard (here is the topic)
    after 4 months it presents a new problem, it turns on and off continuously, the audio can be heard for a few seconds before turning off
    disconnecting the LVDS cables of the display the problem continues
    I noticed that by removing the bridge I had made, the TV remains on with the audio and by connecting one flat LVDS at a time it remains on, connecting them both the main problem remains
    do you have any advice?
    the bridge in photos FB_TRDY_1 and FB_TRDY_3​
  • Storyteller12
    • Jun 2020
    • 624
    Sounds like the panel is bad or possibly shorted caps on the buffer board. If it start to reboot/ power on and off when both lvds cables are connected.
    Guess the mainboard could have went bad again also. I would try the tape method first on lvds cables since it's free and see if the tv stays on and shows picture.
    Do you have an image on the tv when 1 lvds cable is connected?
    Reconnect your bridge wire and try 1 lvds cable at a time and see if 1 side has image or not.
    • giova96
      • May 2023
      • 38
      • italia
      when I disconnect an LVDS I have no image
      I'll try to isolate the pins​
      • giova96
        • May 2023
        • 38
        • italia
        Can anyone check if this file is corrupted?
        • lotas
          • Jan 2016
          • 4555
          • Russia
          Your dump is working.
          • giova96
            • May 2023
            • 38
            • italia
            ok thanks, I think I'll throw away the TV
            even with the lvds disconnected it turns on and off continuously and I don't want to buy another card again, with the risk of the LEDs or screen causing problems (a known defect in these models)​
              09-07-2024, 05:50 AM
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
              09-06-2024, 11:40 PM
