Sony trintron KV-32u35 only the PIP works????
  • saml
    • Dec 2013
    • US
    Hello all and thanks for checking my post. Ive got a problem with my tv. I use a digital converter box with a rabbit ear antenna. As of right now the only video and audio i get is through the PIP ( picture on picture ) window. The normal picture is just fuzz so if i want to watch tv it only viewable through the tiny pip window. I feel like i hit a bunch of buttons one day on the remote trying to figure it out and problems may have gotten worse. Has anyone ever had this problem and or does anyone know a solution other than kicking it to the curb??? thanks
  • R_J
    • Jun 2012
    • 9588
    Re: Sony trintron KV-32u35 only the PIP works????
    KV-32V35
    Check for bad connections on the main tuner module where it mounts to the main board or there may be bad connections inside the tuner module itself. If I remember the sub tuner is located on a seperate board that connects to the main board
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      How about other inputs - scart dvd video pc if it has any do they work?
      Perhaps the STB is not outputting correctly? can you try it on anything else?
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
      • tree5656
        diagnosing sony XBR-75X900H. NO PICTURE
        by tree5656
        This tv is not even 3 years old. its a sony XBR-75X900H, it was like a flashbang went off suddenly, tv faded to black and no picture. backlight is on. tried to do the power cycle, factory reset. i get beeps from remote if i tap up/down but no picture. how can i determine if its the panel or a board? i have replaced boards before im just not sure what the issue is here. sony said nothing they can do and only suggested to find a local repair shop. please guide me here
        11-09-2023, 04:55 PM
      • DKWS89
        Sony XBR 49x900E - Sound and backlight on but no picture
        by DKWS89
        Hey Guys,
        So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
        All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
        12-14-2023, 04:30 PM
      • ronni
        Sony KD-43XE8005 with sound, backlight, no picture
        by ronni
        I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
        When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
        Removing the LVDS cable results in...
        12-01-2022, 08:44 AM
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
