vizio plasma works for few mins then pops off
  • bigred*
    • Nov 2012
    • 18
    • US of A
    So I fixed this tv about a year ago, it had the infamous pop of death and fried some video boards when it went, replaced the boards, and all the bad caps on the power supply, its been working great for about a year now but, it just popped off on me again, no loud pop from a cap going, just went all black, sound is gone also, so no video or sound, the little light at the bottom stayed green though, turned it off and unplugged it, let it sit for a couple min turned it back on and it worked perfect for like 5 min before everything popped off again, I'm afraid I've got a cap going or something so I don't want to keep turning it back on, I'd rather fix the problem before it blows taking other stuff with it.. what should I do, and/or look for? Could it be tempature related? Cuz its like 50 degrees in this stupid house
  • bigred*
    • Nov 2012
    • 18
    • US of A
    Re: vizio plasma works for few mins then pops off
    If its a cap that's going would it already be bulging? And just hasn't completly gone yet?
    • bigred*
      • Nov 2012
      • 18
      • US of A
      Anybody got anything?
      • newtothis
        • Mar 2013
        • 1556
        • england
        Pic of boards and one of entire back of chassis so we can see what we are dealing with... Good lighting with the flash turned off.
          Is "pop" coming from speakers? Could be AC detect fault.
          • brnrubbr
            • Jun 2013
            • 37
            DO you have model #? Pops can be Caps or (what I have experienced) IPMs. Glorious, glorious IPMs.
            • ex250
              Kenwood SW-505D no sound issue and pops from time to time when it works
              by ex250
              Hello mates,
              I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
              It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
              12-29-2024, 03:27 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • bobbyskillz
              Vizio E241i-a1 - works, but OSD stuck and no buttons work
              by bobbyskillz
              Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
              I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
              Thanks for...
              07-02-2025, 03:43 PM
            • berriferous
              Samsung PN43E450A1FXZA (Plasma) - Display up for 4 mins, then shuts itself down
              by berriferous
              Set was manufactured in 2012. I'm trying to diagnose where the problem is. I am assuming it is over-currenting after heating up? Display looks fine until it decides to shutdown. If I keep turning it on, it will eventually refuse to power up and requires unplugging to get it to respond again.
              I originally thought there would be some easily detected bad electrolytic capacitors, but I don't see the telltale signs. There might be some very minimal bulging on one of the x buffer board. BN96-22092A (LJ92-01852A).
              If I unplug the power feed to the X/Y board (LJ92-01854B), the...
              12-16-2024, 09:58 AM
            • pdsterns
              Vizio 42" M420SL works then goes blank
              by pdsterns
              Good Morning TV'ers
              Vizio usually starts and works fine for a few minutes then goes blank. Checking voltages when shutdown it reads 5v on the standby pins on the PS and 12v on the 12v pina, backlights are out now. What can I conclude or where to next.
              Thanks in advance
              burns
              12-12-2022, 08:34 AM
