Hi. I'm in a pickle with this TV, which uses the Vestel 17MB35-1 Chassis. Due to a faulty power supply the SPI flash i.c U114 has become damaged, the set is now working but I have no DVB, just a blank screen, when I put the set into standby I get a flashing blue LED.
I have a replacement i.c but obviously need to flash it, but I can't locate anywhere I can get a complete dump of this ic, I have firmware for the chassis but since this chip also contains the boot code for the MPEG decoder (CT216T) the digital side will not boot up to accept firmware (hence the flashing LED as it also is unable to shut down correctly).
Does anyone else on here have access to a Willem or similar programmer and could dump the contents of a working U114. I'm trying monitor.net (Russian site) since they seem to do this stuff but my post keeps violating the forum rules (maybe bad translation).
The ic type in my set is a Winbond W25X32SIG 32 Mbit SPI flash.
I could always change the main board but this isn't the way I like to work, and it will add an unnecessary expense.
