Insignia ns-32lcd 32" TV
  • monopoly96
    • Nov 2013
    • 16
    I have an insignia ns-32lcd the TV's standby red light flashes continuously once plugged in but no response from on button or remote. The power supply output of 5v is constant and the logic board is sending the on signal successfully. However, both 24v outputs of the power supply start at 24v regardless of the power button being pressed and fluctuate from 24v down to 9v and back up to 24v every few seconds. I've replaced all of the capacitors on the power supply board except for the large filter cap which reads about 295v when the TV is plugged in and is rated for 450v 150uf. Could this be the problem? Or would it be a problem with voltage regulation? Pictures of boards listed below.
  • monopoly96
    • Nov 2013
    • 16
    Re: Insignia ns-32lcd 32" TV
    Also i don't know how i forgot to include this but the tv never changes from black screen and the standby red flashing light never turns blue showing the tv is on. Anyone have a clue on what would be causing this?
    • addytzu123
      • Mar 2013
      • 54
      • ROMANIA
      The 24V rail is bouncing with the connector for inverter in or out?
      If it's in and the voltage is still variyng could be some inverter failure. If the connector is out then you need to dig on the PS 24 rail (assuming that the main board is sending the PS_On signal correct). In this case check the semiconductors from the secondry side D516 to D521.
      This kind of fault may also be produced from the driver chip from primary side, N504 SSC9500 IC. Does it have the correct voltage on it's supply pins?
      Assuming the schematic attached corresponds with your PS!
      In a transistor circuit protected by a fuse, the transistor will always blow to protect the fuse.
      • monopoly96
        • Nov 2013
        • 16
        The 24v rail is bouncing with the inverter in and with it out. I'm not sure if that's the schematic for my PS since mine seems to have a 4800CS instead of an SSC9500 IC. Btw not sure if this is useful or not but the previous owner said it went pop before it died.
        • addytzu123
          • Mar 2013
          • 54
          • ROMANIA
          You should read this thread first, a lot of usefull informations, I see you have the same Power Supply.
          https://www.badcaps.net/forum/showthread.php?t=10576
          Check Budm's picture from post #92 as well
          That "pop" sound might have come from a semiconductor from the hot side (mosfet, diode, IC) or from a fuse. Inspect them all carefully (both side of the PCB).
          All the best!
          • monopoly96
            • Nov 2013
            • 16
            Thanks! The large filter cap seems to be low on voltage so i assume there's something wrong upstream of that on the hot side like you said. I read through that thread the other day and i guess i missed that post. I'll go through the semiconductors upstream of that tomorrow if i get a chance.
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
