50" Philips Plasma TV: NO BACKLIGHT
  • Ahakim
    • Apr 2013
    • 64
    Could someone help...?
    50" Philips Plasma TVC
    Philips S LC7 .2E PA (From inside: all boards are Samsung as well as the panel ..!)
    Model N° 50PFP 5532D/12
    220VAC/380w!!
    Made in Hungary
    Symptoms:
    TV ON (i.e. led on front panel: blue): R 5600 & R5610 next to each other both burning (smoke/fume and oder...). NO BACKLIGHT---No litht on screen at all. Sound OK (with signal from a Demo for instance...).
    These 2 Rs are located on lower extreme left side of Y-MAIN board.
    Hope I could find the schematic, to find out the original fault as well as the values of these 2 1w-resistances. OR any other ideas/suggestions... By the way what are typical values of the volage(s) that excite(s) the plasma gas mixture... to produce light?
    Note: TV is so heavy and embarrassing in troubleshooting!!
    Note: No need for a picture of screen (nothing helpful to see).
  • celiabrown
    Issue with Plasma Philips 37inch chassis FTL2.1
    by celiabrown
    Hello guys,
    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
    Can someone has any symptom like this ?
    Thanks​
    05-09-2024, 10:56 PM
  • alro7779
    Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
    by alro7779
    Hello, guys!
    The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
    09-14-2025, 12:25 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • double_DD
    Philips curling iron - is this a common AC cable?
    by double_DD
    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
    08-18-2025, 10:04 AM
  • janos6662000
    Philips 47PFS7509/12 LCD TV problem
    by janos6662000
    Hi
    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
    When i applied cable signal to check image, i had normal picture, but TV was restarting.
    I downloaded original firmware and applied the update, but the problem remained.
    From a colleague i received a "factory package software" which is a lot bigger.
    I made another firmware update, but still did not solve the problem.
    Somewhere on the way the error got worse, because at the moment the...
    08-12-2025, 12:54 PM
