rca l32wd22 problem
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: rca l32wd22 problem
    Originally posted by j0gigs
    Viceroger69,
    Here are the results of my testing:
    LDO #1 Pin1 no voltage Pin2 3.30v pin3 5.04v
    LDO #2 Pin1 no voltage Pin2 3.30v pin3 5.04v
    LDO #3 Pin1 no voltage Pin2 3.30v pin3 5.04v
    On the inverter board, all 3 of the fuses read 24.04v on both sides.
    The voltages at the cable plugged into the inverter boardare:
    Pins 1-5 (VDD) 24.04v
    pins 6-10 (GND)
    pin 11 -not used-
    pin 12 (BL ON) 3.27v
    pin 13 (VDIM) 3.27v
    The fuse on the tcon board reads 4.85v on both sides.
    I found specs for the transformer here: http://lcdparts.net/TransformerDetai...ProductID=3502
    The secondary resistance should be about 1.2K between S1 and S2 (or S3 and S4) and the primary resistance should be about 0.5 ohm between P1 and P2.
    I checked all my transformers and found all primary resistances to be .4 ohms.
    I also checked both secondary coils on each of the 6 transformers and all were between 1.19k - 1.20k except one. one of the secondary coils was 1.20k and the other was 2.48k.
    Do you think this is my problem?
    Usually see the secondary windings shorted... but that is definitely faulty
    • j0gigs
      • Dec 2012
      • 56
      do you think replacing the inverter board will fix my tv?
      • j0gigs
        • Dec 2012
        • 56
        I just wanted to say thank you to all that helped me with my problem. I installed a replacement inverter board and my tv is up and running again. This thing has Ben sitting around for over a year.
        You guys are awesome! Have a happy holiday!
        • vinceroger69
          • Mar 2012
          • 6714
          glad you managed to fix it and save it from the recyling yes this forum is one of the best i have found.
          • Viejo
            • Dec 2013
            • 3
            • United states
            I have rca 32"132wd22 i renplace some bad caps and works for almost 5 hours now only the green light on not imagen not sound i check the voltages on the power supply i find 5v 12 v not find 15 v and 24 v help to find the bad part on the board
            • mmccomputer
              problem with replacing lcd screen
              by mmccomputer
              I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
              otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
              If anyone has any information on the subject...
              12-15-2024, 03:44 PM
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • Chrissygizmo
              Sony KD-55XG9505 lines on screen problem
              by Chrissygizmo
              Hello again everyone,
              This is my latest mission, to try getting this Sony tv back to normal working order…
              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
              02-19-2025, 11:31 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
