Matsui 42 inch LCD stuck on standby Blue light
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: Matsui 42 inch LCD stuck on standby Blue light
    Its called the child lock feature lol you can turn it off in the menu. When this feature is on the side buttons can not be pressed/dont work.
    • michael dranfield
      • Jan 2016
      • 232
      • England
      #42
      I have been caught out with this a few times over the years , on some sets usually Panasonic and Phillips , if the set is switched off with the remote you have to switch it back on with the remote, this is assuming the child lock has not already been activated.
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
      • Tomylee
        Nintendo 2DS XL – Orange light, no blue light, signs of overheating
        by Tomylee
        Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
        Here's what I've observed:
        All ribbon cables are properly connected
        Battery is present and in good condition
        No reaction even with screens disconnected
        There's a visible burn mark / overheating sign on the metal shield, right above the CPU
        I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
        06-26-2025, 02:33 PM
      • Ady2017
        LG 42LD490 stuck in standby with flashing red light
        by Ady2017
        The problem with my TV is very similar to an earlier post but there was no final solution posted.
        When the TV is first turned on from cold it will not turn on. The red standby light begins pulsing and a high pitch whine is heard. The back light remains off. If the TV is left trying to boot like this and then turned off and on again a few times then eventually it will turn on and sit there working all day long.
        I initially suspected the PSU after spotting this kit for sale,
        http://www.ohmsupplies.co.uk/epages/...ops/62027733/P...
        11-16-2021, 11:10 AM
      • brithepi2k
        Sony KD-65XE8596 no standby light
        by brithepi2k
        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
        cheers...
        09-06-2025, 02:22 PM
      • Kaar3l
        Samsung QLED QE65Q7FNAT only standby light
        by Kaar3l
        TV: Samsung QLED QE65Q7FNAT
        PSU: BN4400940A
        MB: BN94-12832K
        I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
        09-24-2024, 01:35 PM
