Alba lcd32880hdf
+ More Options
Posts
    Re: Alba lcd32880hdf
    If you had 24V before make sure all your jumpers are in place like the ones for STBY ON/OFF...
    • sordids999
      • May 2013
      • 2158
      tom if i use the jumpers on
      pin 6 STBY_ONOFF
      pin 8 BL_ON/OFF
      pin 10 B_DIM
      pin 14 +5VSTBY_2
      then i only get 5v from the blue wire and no 24v
      if i use a jumper on
      pin 6 STBY_ONOFF
      pin 8 BL_ON/OFF
      pin 10 B_DIM
      i get 24v on invertor but the blue cable is 0v
      i can short the backlight to come on but it just flickers using
      pin 6 STBY_ONOFF
      pin 8 BL_ON/OFF
      pin 10 B_DIM
      pin 12 +12V
        I'll try and have a look at this tomorrow. Bump up the post if I forget.
        I do remember when I jumpred the backlight on the 26" 17PW25-4 it flickered for the first 3 seconds... I think it wanted to stabilise the output first which the main board would normally wait for.
        • sordids999
          • May 2013
          • 2158
          ok thanks m8
            OK, so to confirm, the backlight is flickering continuously? What is the 24V doing? Is it stable?
            • sordids999
              • May 2013
              • 2158
              #26
              pin 6 STBY_ONOFF
              pin 8 BL_ON/OFF
              pin 10 B_DIM
              pin 12 +12V
              yes the 24v is stable i can only get the backlight to flicker by touching pin 12 with a wire ,if i leave the wire in pin 12 then it trys to start backlight but it fails so i have to keep shorting pin 12 to make the backlight flicker
                What about if you also connect pin 28 on the connector going to the main board?
                This is by far and away the most complicated backlight jump I have ever seen, it is usually very simple, I cannot think why it would not work.
                • sordids999
                  • May 2013
                  • 2158
                  #28
                  just to confirm im doing the correct pin sequence tom ?
                  via pictures
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Could always be bad back light ccfl? or Inverter transformer?
                    • sordids999
                      • May 2013
                      • 2158
                      #30
                      already tried another invertor luckily i had a spare
                      • sordids999
                        • May 2013
                        • 2158
                        #31
                        ok again tom thanks for your help ill leave this for a rainy day got my latest project bought 4 days ago PHILIPS 47PFL7603D/10 for £30 supposed to keep cutting out but still waiting for this to happen
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          Some people seem to have had problems and success with changing the high voltage blue caps see here
                          http://www.tv.quuq.org/forum/index.p...e;topic=5167.0
                          • sordids999
                            • May 2013
                            • 2158
                            #33
                            yeah thats a different psu with the built in blue caps that runs the invertor ive changed them before and fixed this but this tv is a different version with the invertor board seperate
                              I can't remember which is pin 1, to check you would need to find the 5 grounds which hang off pin 1, for some reason Vestel have seen fit not to label it!! Ugh.!
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • Capacitorial
                                Powersupply has all the voltages - Monitor still no power
                                by Capacitorial
                                Hello guys,
                                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                The weird thing is, that the Power LED is powered over the TCON board.
                                On The TCON...
                                12-28-2024, 02:12 PM
                              • ygorsan
                                by ygorsan
                                🧩 Problem Summary:
                                • I
                                07-28-2025, 08:34 AM
                              • Asraf Atb
                                by Asraf Atb
                                01-27-2025, 05:02 PM
