Samsung lj92-01200A Y-SUS Board
  • SevillianSTS
    • Nov 2013
    • 31
    I mentioned my issue in a different thread, but decided I'd try and make one dedicated to my issue.
    I have a lj92-01200A that came out of a Sayno 42" Plasma TV
    I confirmed the lower Y Buffer had a shorted IC
    I then found 3 shorted MOSFET's on the Y-SUS board.
    I have replaced those mosfet's that were shorted G to D, but the TV power board still clicks on and then right back off a second or two later, and then the one green LED flashes 12 times over and over with the Y-SUS installed (no buffers connected)
    I did notice that I can leave the power cable plugged into the Y-SUS and if I do NOT plug in the small ribbon cable below, the TV power will stay on.
    I feel I'm so close, but not sure what else to check, any ideas ?
    Thanks,
  • SevillianSTS
    • Nov 2013
    • 31
    Re: Samsung lj92-01200A Y-SUS Board
    Anybody want to step in and help a novice troubleshoot this?
    • Videojoe
      • Sep 2013
      • 47
      • Us
      I have been working on that same board and its a real pain, there are many posts about it here. There are 2 diodes and 2 resistors that need to be checked on this unit also. If you click on my screen name to see my other post, these guys outlined it in detail. In addition to that, you basically need to check every single diode and fet on the board because sometimes you get a random bonus pop along with the usual parts that always blow. Really bad design.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • modtool
        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
        by modtool
        Hi to all,
        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
        04-01-2025, 08:22 AM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
