Sanyo plasma tv main tuner board question
  • gillisfire
    • Nov 2013
    • 16
    I have been looking for a main tuner board for my Sanyo DP50749 50inch plasma tv. The board that is in my tv is a JF4E. While looking for this part, I found that the DP5079 model also has a tuner board J4FH. They both have the same board part number 1AA4B10N22900 except the J4FH part number has an _A after it (1AA4B10N22900_A). From what I can tell every thing is the same. Looking over the pictures and studying everything I think the J4FH is maybe a more up to date board.
    So I was wondering if I could use the J4FH in place of the JF4E.
    Re: Sanyo plasma tv main tuner board question
    AFAIK one of the issues with these TVs is they used Samsung, LG and Panasonic plasma modules... so it's important to make sure you use the board which belongs to the right panel module or it won't work properly. Don't know how much that helps but something to watch out for.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
