Hello i have a un46d6050 with no pictures I've tried changing the t-con board the power board and the main boards all of which were purchased from ebay but still all i keep getting is sound and no picture just a blue screen
samsung UN46D6050 sound but no picture
Tags: None
Re: samsung UN46D6050 sound but no picture
Check voltage on t-con fuse but it's quite likely as munirutech said that the panel is bad. Especially if it has ever been splashed with water. Try disconnecting one t-con ribbon at a time too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I have a Samsung UN46D6050TFXZA TV that I purchased a while ago, and have not been able to fix it. I had mentioned the TV on this thread, but at that time I thought it was the mainboard, only to find out that it sells over $110. I decided to keep the TV and find a broken one so I can take the mainboard, and that's what happened this weekend. I purchased a broken screen model UN55D6000SFXZA and luckily the mainboard and t-con are the same.
The original problem of the UN46D6050TFXZA TV is that there is sound, but no video. You can see the tv flashes when you turn it on, and it flashes when you change channels, but no video. So I replaced the mainboard on the UN46D6050TFXZA (BN94-05038F) and used UN55D6000SFXZA (BN94-05038D) mainboard, problem persisted, sound but no video and the same symptoms described above. The mainboard is identical and on the internet it showed me the substitute parts and model was there.
Now, I replaced the original t-con on the UN46D6050TFXZA and used UN55D6000SFXZA t-con, and the SmartTV logo came up, but you were able to see that the brightness on it was dissapearing, like using for example a knob that you control the power from high to low. The SmartTV logo when from high to low, the sound came up, but could not see the channels. I replaced the mainboard that I was using from the UN55D6000SFXZA TV (BN94-05038D), and installed the original one (BN94-05038F), the problem persisted. I replaced the t-con I was using from the UN55D6000SFXZA TV and installed the original t-con that came with the UN46D6050TFXZA, problem persisted.
I have checked the power supply board (BN44-00423A (PD46A1_BSM)). The rectifier gave me correct readings. Inside pins 120VAC, outside pins 166VDC. Checked the 450v capacitor and it gave me 166VDC on standby, when I powered the TV it gave me a reading of 386VDC. The are two fuses on the board and they had continuity.
I do not have the TV with me, its a my dad's house cause that's where we were working on it, but the power supply is this one:
BN44-00423A
Anything else that I can do?
I'm suspecting it is the power supply.
ThanksLast edited by rlega; 12-31-2014, 04:51 PM.Comment
make sure all your power supply voltages are proper at the connectors/cables going to the other boards, hopefully theres a legend by the connectors, careful when working with power supply, HIGH VOLTAGE on primary side.Comment
You are right. I'm careful when I do testing.
ThanksLast edited by rlega; 12-31-2014, 05:11 PM.Comment
check tom66's post #3, see if you can find a manual, its in the small print.Comment
Blue screen - slight backlight leakage?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The tv doesnt have backlight leakage.
I'm really scratching my head on this oneComment
can you post some good clear pics., of each board and one of how they are all connected, this is an led tv, folks forget to put type of tv in initial post, it makes it tougher to have to google to find out what type it is.Comment
Re: samsung UN46D6050 (LED TV) sound but no picture
Sorry I did not open a thread since this one was open, I used it, but I have added the word LED at the title of my postComment
Here are a bunch of pictures
Hope this helps, thank you!Comment
Have a look at the LVDS signal with the oscilloscope. While checking the LVDS signal, press the menu button and turn the menu on and off on the tv. As you do that, the waveform on the oscilloscope changes. This way you know that your main board is working o.k. or not. The LVDS signal is quite low btw.Comment
I do not have a oscilloscope.
I do have a question though. On the power supply board, there is a capacitor 223js1000v (CM813).
I purchased a board on ebay, and the board arrived without the capacitor. The board will be shipped back, so they can solder it, but in the meantime, I'm trying to find the same capacitor so I can ordered it.
I found this on ebay.
Is it the correct one? If its not, could someone please let me know where I can get it?
ThanksComment
http://www.digikey.com/product-detai...1901-ND/502681
Polypropylene (PP), Metallized
High Pulse, DV/DTNever stop learning
High Pulse, DV/DTComment
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by iglitareHi,
i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
Backlight seems to work, Sound (Setup menu after reset) works.
If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
With my small knowledge i would think at least the cables are good.
Can this happen because of a bad tcon board?
Or is it always a bad/shorted... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by DodgethisHello all,
This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...5 Photos - Loading...
