Vizio bp50-hdtv2a
  • Ovalking
    • Jul 2013
    • 57
    • Usa
    Vizio bp50-hdtv2a
    Does any one no the resistance of r5600 and r5610 on a
    Y sus board on a vp50 hdtv20a tv thanks
  • capkid
    • Oct 2010
    • 1339
    Re: Vizio bp50-hdtv2a
    According to this post, if it's the same Y-Sus, those resistors appear to be 10 ohms: http://www.fixya.com/support/t124065...tv20a_am_going
    LG Plasma Mal-Discharge Correction Service
    • PlasmaRon
      • Nov 2013
      • 40
      I'm working on 2 of those same models, if you haven't got the answer, I can make measurements for you.
      • Ovalking
        • Jul 2013
        • 57
        • Usa
        Thanks capkid plasma Ron do you no what mosfets to replace
        There's a kid on eBay that says you need to replace 6
        Of them but my board has 10 also I'm getting 5.2 ohms
        Each on my resisters should the be 10 ohms each or together
        • capkid
          • Oct 2010
          • 1339
          The resistors are 10 ohms each. Did you lift at least one leg of each resistor from the circuit to check the resistance? If they are in parallel, and you didn't lift a leg, the 5-ohm readings you got are correct.
          • PlasmaRon
            • Nov 2013
            • 40
            Ovalking, Sorry I really can't help much with component repair. I pretty much just do board replacements. The set(s) that I'm working on are the VP50HDTV10A and I see that the Y boards are EAX34151601. I don't see any resistors labeled like that on my boards.
            • capkid
              • Oct 2010
              • 1339
              What issues are you experiencing that necessitated a repair?
              • Ovalking
                • Jul 2013
                • 57
                • Usa
                No video
                • capkid
                  • Oct 2010
                  • 1339
                  Is the screen totally black? Do your buffer ICs have any burns?
                  • Ovalking
                    • Jul 2013
                    • 57
                    • Usa
                    Yes one on top board has pin hole in it I think I found
                    One bad cap and 6 hidden mosfets does any on no
                    Part number for mosfets
                    • capkid
                      • Oct 2010
                      • 1339
                      What do you mean by "hidden" mosfets? A pic or two might be helpful. This TV sounds very similar to the infamous HP-T50 series TVs, where the K2837 and B20NK50Z (this one sometimes fails) mosfets fail: https://www.badcaps.net/forum/showth...t=24844&page=7
                      The repair kit you referenced earlier is probably this one: http://www.ebay.com/itm/SAMSUNG-Phil...-/130975615950. The buffer will obviously have to be replaced or repaired.
                      • Ovalking
                        • Jul 2013
                        • 57
                        • Usa
                        They were below heat sink behind blue resisters I think
                        I'm new but I'm learning thank everyone here for the help
                        Thanks capkid ill look at other thread when I get off work
                        • Ovalking
                          • Jul 2013
                          • 57
                          • Usa
                          You are correct capkid that's the kit there is 4 that are the same
                          And 2 that are the same do you no part numbers ?
                          • capkid
                            • Oct 2010
                            • 1339
                            On my board, which is LJ92-01490A for the three 50" Samsungs I worked on awhile back, I had to replace these mosfets on the lower bank:
                            - 88N30W (four of these)
                            - K2837 (one of these)
                            - B20NK50Z (one surface mount mosfet)
                            I'm not sure what's included in the eBay seller's kit. Also, I've purchased from this eBay seller (SLP5188) numerous times without an issue: http://www.ebay.com/itm/AP88N30E-88N...item2ecbb5a1e9
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • mrtek
                              Vizio M65-C1
                              by mrtek
                              Hi.
                              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                              07-14-2025, 07:28 PM
                            • howardc64
                              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                              by howardc64
                              Failure Symptom
                              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                              Where is the short?
                              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                              05-27-2025, 02:56 PM
                            • howardc64
                              Vizio SmartCast TV software bug that looks like hardware
                              by howardc64
                              Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                              It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                              11-16-2024, 05:17 PM
