Samsung LED starts up black screen then reboots itself veritical blue lines
  • BrentH561
    • Jul 2011
    • 16
    Samsung UN46C6300
    Picked this up from a friend that said while watching it the screen would flicker and go to a green or black screen .To correct this issue temporarily he would give it a knock on the back panel in the area of the board where the hdmi ports plug. I will test the fuse on the T-Con board as I have ready that this may be the cause. I have made sure all of the ribbon connections were properly secured. Any help greatly appreciated!
    Screen that appears after continuous restarting itself is shown below. The screen will take around 10 seconds to appear from the time I hear the click of it powering on. The screen will be black before it appears.
    Mainboard
    TCon
    HDMI board
    Re: Samsung LED starts up black screen then reboots itself veritical blue lines
    That looks a lot like a main board fault (the one with the HDMIs)
    • tibimakai
      • Jan 2012
      • 3680
      The one that I have repaired, it was just rebooting in a loop and a "new" mainboard fixed it.
      It has a screeching sound also?
      • BrentH561
        • Jul 2011
        • 16
        Thanks for all the help. I plan to replace the main board. Will post back with results.
        • BrentH561
          • Jul 2011
          • 16
          Installed a main board i picked up off ebay and the unit starts up and seems to run my xbox and satellite perfect on hdmi 1. However when running my pc to hdmi2 i see a slight green flicker across the screen on the bottom. I am fairly certain this problem only happens when using hdmi port #2. Is this indication of a faulty main board?
          • newtothis
            • Mar 2013
            • 1556
            • england
            test your xbox on HDMI 2, also switch cables to rule them out
            • freakaftr8
              • Oct 2012
              • 3743
              Also wiggle the hdmi cord in the hdmi 2 socket and see if it plays up. If so either bad cable, bad hdmi socket or bad solder connections on hdmi 2 input.
              • tibimakai
                • Jan 2012
                • 3680
                I always install the latest firmwares.
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
                • Ariel Ruiz
                  Acer Aspire A315-41-R8J9 starts with blank screen, does nothing.
                  by Ariel Ruiz
                  Hi, I will appreciate if I can get some advice on my problem.
                  - I have an Acer Aspire A315-41-R8J9, with Ryzen 5 APU (no GPU).
                  - The laptop can be started (blue led on) but it shows no picture (blank screen), and it looks to be somewhat active, as the fan spins, and processor gets hot.
                  - I visually inspected and tested some components, with no obvious issues.
                  - I disconnected not-essential peripherals.
                  - When testing PL401, I got sparks, smoke smell, and the Acer logo briefly showed in screen but then shut down.
                  - I tried to re-flash BIOS from USB (Fn+Esc),...
                  05-19-2024, 01:04 PM
                • ipatch
                  ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                  by ipatch
                  i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                  08-24-2024, 02:36 PM
