Panasonic Viera TX-L37ET5B LED
  • Manddave
    • Oct 2013
    • 58
    • Uk
    Hi I have a Panasonic Viera TX-L37ET5B LED which suffered water ingress to base of screen.
    There is no visible damage to anything and i have backlight and sound
    My question is would this be panel failure?
    here are a couple of pics
    Re: Panasonic Viera TX-L37ET5B LED
    No picture?
    Are the tab connections at the top or bottom of the screen?
    Most likely it would be unrepairable.
    I recently received a 37" LG with half the picture out, bad panel due to water ingress.
    So many of these dying due to water damage .
    You can try unhooking one half of panel at a time, if you get half a picture, most likely one of the tabs is shorted, which is not repairable.
    • Manddave
      • Oct 2013
      • 58
      • Uk
      Hi
      i still have no picture when unhooking the tcon on either side just get half white screen.
        OK, have you checked the fuse on the t-con?
        • Manddave
          • Oct 2013
          • 58
          • Uk
          Hi where is the fuse on the tcon
          Can you point it out please
          • newtothis
            • Mar 2013
            • 1556
            • england
            Clearer picture so can see the writing.
            Usually marked like this F20/3.5a
            *** Tom got there already ***
              Little white device with gold/silver coloured caps, near the connections on the left.
              • Manddave
                • Oct 2013
                • 58
                • Uk
                Ok thanks i will look at this in the morning due to being at work tonight.
                Whats the best way to check this fuse?
                Like i said earlier i get half white screen when disconnecting tcon from panel.
                And i have also unhooked from driver board and its just the same no picture just backlight.
                I will try and get some better pics tomorrow.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Continuity setting, Diode setting, Ohm setting
                  Any will work to check it
                    Also check volts each end red probe on one end black to chassis, repeat for other end. Should be about 12V each side.
                      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                      by sam_sam_sam
                      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                      04-09-2023, 08:04 PM
                    • mostachio
                      Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                      by mostachio
                      Hi Badcaps,
                      I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                      TV Details:
                      Model # - TH-65DX700Z
                      Symptoms:
                      The television turns on and displays a picture then makes a clicking sound and turns off.
                      I haven't opened it up yet but...
                      09-04-2024, 02:32 AM
                    • armoured_smiler
                      Panasonic Tx-40cx400b top left half screen not displaying correct
                      by armoured_smiler
                      Trying to work out if this is TFT problem or TCon issue.
                      The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
                      Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
                      04-08-2024, 03:40 PM
                    • Ama Chur
                      Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                      by Ama Chur
                      After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                      02-21-2025, 08:12 PM
                    • badcappo
                      Dead Panasonic Viera TX-P65STW50 Plasma TV
                      by badcappo
                      Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                      Diode type G972s6 - D101 with a short
                      Mosfet 06N90E - Q301 shorted
                      Fuse T5AH 250V - F103 blown
                      Diode D301 shorted
                      Relay DG1U-17VDC II - RL001 blown
                      I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                      11-24-2024, 11:27 AM
