Re: Baird x37DTV - No Power
Lesson 2 :
1 means Infinity... Look at a DMM the same way as decimals... 1 being a whole and anything under it as points of a whole.
So... for example if testing a resistor - Lets say infinity is 1000ohms which will show as 1 - you test the resistor and it shows 474ohm on the DMM screen, the resistor is only letting 526ohms of that 1000ohms back through to the DMM... The DMM figures it has sent 1000 and lost 526 in circuit so 1000 - 526 = 474. If you were to test and it showed 0 it would be letting 1000ohms through as it isn't restricting anything which is a short circuit S/C. If it were to read 1 then its letting 0 of those ohms through and therefore open circuit O/C.
Hope that makes sense.
Also Open and closed (short)... Imagine it is a gate in a garden... when closed power can run through the hinge and across the gate and through the latch on the other side. When open the power hits the latch but has no where to go.
Originally posted by DJ4D
View Post
