Muller 32'' lcd
  • willyam1
    • Feb 2012
    • 112
    • israel
    Muller 32'' lcd
    HI TO ALL.
    this one came with no backlight and a burning smell.
    found in the lip p.s fire in the backlight plug.
    i clean the burn area operet it again and its the same start to burn .
    i check the 2 10pf 3kv capi ballast are ok i operet it with one left backlight no burning and can see a some light in the screen same with the right backlight.
    but when the 2 backlight coneccted star to burn.
    i clean again that wont be any short.
    the transformer of the high valltage is BCK35346WH 3011.
    PRIMERY 0.3 OHM SECONDARY 78 OHM ITS SEEM TO ME THAT THE PROBLEM IN THE TRANSFORMER could be that the secondary is too low?
    POWER SUPPLY LS3212003-00-GP.
    ANY SOLUTION?
    WILLYAM
    Re: Muller 32'' lcd
    Check bulb connection or bulb isn't shorted to panel chassis in any way.
    • willyam1
      • Feb 2012
      • 112
      • israel
      Re: Muller 32'' lcd
      HI TOM66.
      i already check for short in the bulb connection no short to pannel chassis and also the backlight is working for a few sec when its connected seppertly but when they conectted both problem start. i notice tht this transformer was alredy handel by another tech and the custemer told me that the service center alredt repiar the tv and the problem was no backlight a few month ago
      willyam
        Re: Muller 32'' lcd
        Are there several transformers? How do their measurements compare?
        • willyam1
          • Feb 2012
          • 112
          • israel
          Re: Muller 32'' lcd
          only one.seems that the sec is too low?usally its kilohms.
          willyam
            Re: Muller 32'' lcd
            It could well be bad then. That could indicate a shorted turn or otherwise bad transformer.
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • stormanimal83
              Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
              by stormanimal83
              Hey....
              Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
              my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
              01-18-2024, 02:15 PM
            • ignacio.ino27
              Vaio DA0HK1MB6E0 MBX-247 Burning any EC
              by ignacio.ino27
              Hello to all.
              I have this Sony Vaio QUANTA HK1 DA0HK1MB6E0 MBX-247 that is burning the NUVOTON EC when you connect it to power supply.
              1) The +3vpcu line is going to a direct short after connecting the motherboard to power supply.
              2) I discovered the EC NUVOTON was shorted. After removing it the short gone out on that line (+3vpcu) but... (If i quit the EC the 3.3v are pressent on +3vpcu because the shorted component was quited)
              3) There were no shorts after soldering the new EC NUVOTON. But after connecting the board to power supply the EC keeps burning...
              05-07-2022, 05:24 PM
            • Seville
              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
              by Seville
              Hello all!
              Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
              I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
              10-10-2022, 07:31 AM
            • androw ezzat
              HP ZR22W burning mode
              by androw ezzat
              hallo i have HP ZR22W
              ​ have burning mode the screen flicker bule.green.whit .red
              05-03-2025, 03:01 PM
