Samsung LN32D403E4D - Jumpy/Double Image
  • ohmmy
    • 182
    Re: Samsung LN32D403E4D - Jumpy/Double Image
    Originally posted by tom66
    Think this is the device
    If it's working, and conducting, voltage between B-E (outer two pins) should be approx 0.7V.
    ...and it's not a 1117; replacing it with one may cause damage...
    Is VSS definitely positive? I suppose it could be what SAMSUNG call VCOM. It would not cause jumpy image.
    Jumpy image could perhaps be caused by VGH/VON or VGL/VOFF going bad.
    Weird that a 1117 caused no issues and same symptom?
    Actually the VSS was a negative voltage -7.43v
    What is VGH/VON VGL/OFF?
      VSS therefore must be VOFF/VGL as I thought. So -7.5V approx is fine for that. Try and find the +20V to +30V supply. It will be on there somewhere.
      • ohmmy
        • 182
        Would it be labeled something?
          Yes.
          • ohmmy
            • 182
            Found these:
            VONE: 27.6v
            VOFF: -11.3v
            VSS: -7.43v
            HAVVD: 7.50v
            All tested with original N2 diode back in
            • ohmmy
              • 182
              Any good? Also, why can't I find more than one tab bond on this. Doesn't make sense there'd only be one for the entire panel
                Those look reasonable.
                I'm guessing it's an unrepairable fault.
                As for one bond, it's a new direction LCD TVs are going in. All the panel drivers (all 4,098 columns) fit into one bond now to save money.
                Previously I've seen as few as two, never just one until now.
                • ohmmy
                  • 182
                  Ah. Why do you think hitting that diode with the freeze spray caused the image to attempt to go normal?
                    It's not a diode, it's an NPN transistor. Perhaps you were cooling the tab too? I forgot about that, it is odd. Would help to get a scope out and check the various signals.
                    • ohmmy
                      • 182
                      I directly cooled the tab too and picture was only affected by cooling the transistor. Don't have a scope
                        What happens to VOFF and VONE if you cool that transistor?
                        • ohmmy
                          • 182
                          VOFF: -18.54 when sprayed and quickly goes up and stabilizes to -11.37
                          VONE: stays the same when sprayed at 27.6V
                          Voltage drop across the transistor from B to E is -0.6v
                          Also when the voltage at the base of that transistor drops to -6.67v is when picture is 85% better (when freeze sprayed)
                          • ohmmy
                            • 182
                            I'm tempted to try adding a resistor before the base of the transistor to drop the voltage down to around -5v and see if that gives a better picture? Lol
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #34
                              Its worth a try
                              • ohmmy
                                • 182
                                How would I calculate right value resistor to use?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #36
                                  Oh I am sorry I am having a bad day and not thinking.
                                  A resistor will not work... Resistors reduce current not voltage.
                                  To drop voltage you need a regulator
                                    Actually a resistor could work by loading down that output. But I would only consider that a temp fix and replacing that transistor is likely the permanent solution.
                                    So, -18V, picture poor (expected: very lucky LCD panel doesn't fry!) and -11V, picture OK? Or other way around?
                                    • ohmmy
                                      • 182
                                      Other way around, -18v when it's cooled and the picture is trying to rejoin into one image
                                      Is that transistor definitely bad? I measured -0.6v across base and emitter
                                        That is well beyond what I would expect for most LCD panels! It is possible this Samsung does it differently but I would be surprised.
                                        If you have an NPN through hole transistor lying around you could probably do a quick check and put it in place of the existing one. Link to the datasheet and we can see if it will work.
                                        • ohmmy
                                          • 182
                                          So I have no idea what happened, but now the picture is way worse!
                                          The gamma chip is super hot to the touch now but the measured voltages from it aren't all over the place, they give steady lows/highs
                                          If I cool that same npn transistor now, there's no affect. Here's a pic
                                          • Cornito
                                            Samsung UE55RU8000 reboot and then double image after heating up
                                            by Cornito
                                            Hello team,
                                            I'm back with another tv and another problem.
                                            I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                            First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                            Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                            Then double image reduce in height and move to the top.
                                            The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                            When I...
                                            03-31-2024, 01:37 PM
                                            09-07-2024, 05:50 AM
                                          • howardc64
                                            TCL 49S405 double image
                                            by howardc64
                                            LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                            This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                            06-23-2025, 03:20 PM
                                          • shlomim412
                                            samsung ua55es6800 - no image
                                            by shlomim412
                                            hi
                                            having problem with samsung ua55es6800
                                            tv had backlight on, sound working - responds to the remote control but no image.
                                            check tcon board - had 12v in but no other voltages present.
                                            when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                            when leaving only left side connected - again no voltages and no image.
                                            put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                            kept trying to block less pins on the left ribbon cable...
                                            05-15-2024, 05:00 AM
                                            09-06-2024, 11:40 PM
