Phillips 42pf9630a/37 7 red blinks
  • Jim1590
    • Jul 2013
    • 98
    Here is another (and probably next to last from my batch of 7 that I got in a bundle) tv to figure out. Got this one somewhat diagnosed as a Y sus issue.
    Symptoms:
    No power 7 red blinks
    Power board error code of 3 blinks (VSet)
    Multimeter Readings TV plugged in with error code present
    Power board to Y sus
    D5V 0.73v
    Vg 0.37v
    VScan 0.07v
    VSet 18v but falls to nothing while plugged in
    VS 2.2v
    VS 1.9v falling
    Unplugged each Y buffer, no change
    Unplugged Y sus main from power board and tv powered on with no blink codes.
    So I am thinking I need a new Y sus and maybe buffers. Problem is the $ for them. I have no desire to sink more than $60 into the set because I probably would only get $100 selling it. The sus can be had for that 60 but the buffers along with it adds another 100.
    I would like to diagnose if the buffers are in fact bad if able and if they are good, fix the board itself if able.
    I am a bit reluctant to spend money on this as I sunk way to much into a Philips 42pf7320a/37 before I just junked it. This one is just a couple model upgrades.
    Thanks all
  • Jim1590
    • Jul 2013
    • 98
    Re: Phillips 42pf9630a/37 7 red blinks
    OK, found the Coppell blog for this:http://blog.coppelltvrepair.com/2010...er-boards.html
    Upper board I got 125 ohms set to 200k. Lower I got 0.0 both directions.
    Also found this: http://www.youtube.com/watch?v=51SZsfH60EY which was a nice short video and I got no readings on upper but shorts on bottom.
    Is my reasoning sound good the upper should be working?
    • Biruslapio
      Panasonic P58V11B 8 and 12 blinks error "fix"
      by Biruslapio
      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
      04-13-2021, 07:13 AM
    • gatto
      LG 50PC56 keep burn Buffers Boards
      by gatto
      Hi, I’m new to the forum and this is my first post, so thank you in advance to having me, I have the fallowing problem, could someone please help
      I have this LG 50PC56 which not display image on screen
      I have already change Y-SUS and buffers 2 times! But this TV keep burning my buffers boards!
      When I do install the new Buffers board I been able to see only the top half part of the screen for about 10 min, and then it blow up again! The IC get very hot and I saw some smoke come out from it, so now I have another set of buffers burn out
      My question it is: I disconnect...
      05-04-2022, 01:35 AM
    • Andre Gilbert
      by Andre Gilbert
      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
      11-20-2024, 08:52 PM
    • Taurus12
      Optiplex 3050 micro 2 blinks followed by 3 blinks issue
      by Taurus12
      Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
      I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
      i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
      Any recommendation on what I have to do next? Thanks in advance
      06-10-2025, 05:05 PM
    • AtomicPunk
      Phillips 42PF7421D/37 Chassis EL1.1U AA - 2 long, 5 short blinks no display
      by AtomicPunk
      Phillips - Model 42PF7421D/37 - Chassis EL1.1U AA
      No display - 2 long, 5 short led blinks - is this error code 25?
      I've downloaded the training manual and chassis manual from another thread. Lot of information to try to digest.
      I see no visible capacitor issues - fuses checked and are ok.
      Any tips on voltage check points would be appreciated....
      01-04-2020, 03:07 PM
