Element ELCHW321 Catastrophic Failure
    Re: Element ELCHW321 Catastrophic Failure
    Yes, that is correct, just do not let the probe slip.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4949
      • New Zealand
      #62
      I also advise against any wandering probes - I already did that once myself.
      The resultant fireworks may give a good adrenaline rush but they are brief and expensive compared to contemporary gunpowder types and not really worth the lasting headache.
      -David VanHorn
      • mmartell
        • Oct 2013
        • 3189
        I'm fairly confident I can do this with the probes as it's an 8-pin ic and only pin 4 is the gate. What kind of results am I looking for exactly ?
          To see if it draw at 0.5A or more, you may see the current surge at the beginning then it should drop down below 0.5A.
          • mmartell
            • Oct 2013
            • 3189
            Well I'm not sure what to make of that test. I had the lamps disconnected as it's the only way I can get to the bottom of the board.
            With a voltage reading about 1.3v on the 5v line I switched the probe over to AMPs and switched the meter into the amp range as well.
            I was reading 0.00 so I switched to mA scale and now it would read a peak that varied (max about 125ma) but would settle to zero in a matter of seconds. Could only get a reading by removing one of the probes and retouching. Always returned to zero soon thereafter.
            What's up with that ?
              OK, I would solder the wires to the S and D, connect everything back together, turn on the TV, then short the two wires together to simulate MOSFET on condition, if the switched 5V is OK, then the TV should function, then you will know that the MOSFET is bad.
              • mmartell
                • Oct 2013
                • 3189
                I like that idea
                • mmartell
                  • Oct 2013
                  • 3189
                  Well yoda, you nailed it. Soldered a wire from S to D and set works beautifully.
                  Since the 5v supply is switched by the 12v supply do you see any reason why I shouldn't just leave the jumper in ?
                    That switched 5V must be sequenced on after the 12V is on, otherwise they would not have designed the circuit that way. If you leave the wires connected, the switched 5V will always be present even when the TV is turned off.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Actually it has no problems with the on/off sequence as it is now, but if you're saying it could damage something down the road I will swap out the mosfet.
                        You need to make it turns on after the 12V is on, we do not want the surprise later and I do not think it is good idea to have the switched 5V be on all the time, they have it turned off when in standby for reason.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Roger roger I will swap out the mosfet in question.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Mosfet V813 has been replaced and full voltage to the 5v line has been restored. Set works as it should now.
                            Much thanks budm !!
                              Thanks for the feedback. That was fast, you have the MOSFET in stock? Started on Nov 2013, fixed in May 2014, I am glad you did not give up on it.
                              Also really to have thanks newtothis for providing the SCH, otherwise we may not have gotten this far.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Well I let it sit for a long while until I bought this power supply instead of attempting to fix the train wreck that the original one was. Thanks again and here's a pic of the landfill "escapee"
                                As an aside Diane Sawyer just refuses to age !
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Yes of course, thanks newtothis !! To clarify I had the old power supply which I harvested the mosfet from.
                                  This was the first tv I bought to repair after I fixed my neighbours by replacing the main board so I feel sorta like I've come full circle )
                                  • Repler
                                    • Dec 2016
                                    • Usa
                                    #77
                                    I'm working on this exact board, looking to replace C810, C834, and C808. The schematic shows different specs than the capacitors physically on the board - does that matter?
                                    For example, C810 is on the schematic as 220uF/450V and what's physically on the board is 150uF/450V.
                                    The TV used to work just fine, and these look to me to be the original caps. Should I follow the schematic or just replace what's there?
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4949
                                      • New Zealand
                                      #78
                                      The original design would follow the schematic, but likely they found later they could use cheaper parts in production and get away with it.
                                      You can probably follow either\or. But copying what was already there is probably cheaper.
                                      -David VanHorn
                                      • flysky
                                        Gigabyte H610M S2H V2 help to identify the element.
                                        by flysky
                                        There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                                        Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                                        01-23-2025, 07:21 PM
                                      • EasyGoing1
                                        The best way to drive a heating element?
                                        by EasyGoing1
                                        I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                        What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                        This is the general setup that I have now.
                                        This is what the...
                                        01-25-2023, 11:29 AM
                                        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                        by sam_sam_sam
                                        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                        12-16-2023, 08:39 PM
                                        Surface Mount Fuses Fundamentals Datasheet
                                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                        10-07-2024, 06:07 AM
                                      • Sus256
                                        HISENSE 65E7KQ PRO - no boot
                                        by Sus256
                                        Hi all!
                                        HISENSE 65E7KQ PRO
                                        RSAG7.820.13512 - chassis
                                        MT9618BAATAB - cpu
                                        RSAG7.820.12059 - power
                                        HD650Y3U77 - panel
                                        KLM8G1GETF - emmc
                                        The TV does not turn on, the standby indicator is on. All voltages are present.
                                        Emms is dead. Not readable, not detected.
                                        Replaced emmc.
                                        But with another dump there is no launch
                                        Terminal log
                                        UART
                                        AC_ON
                                        RPMB key is not yet programmed
                                        HASH1_VERSION=0x00000000 64bit
                                        E-B
                                        FDE enabled
                                        layout pattern onebin by SAR7,0...
                                        06-01-2025, 02:11 AM
