LN-S3251D - Replaced 3 Capacitors, Blank Screen, Backlight ON - Has Sound
  • zdsh07p9
    • Nov 2013
    • 155
    As described in the title, I have a 32" Samsung LN-S3251D I picked up for a few $ the other day. Found one bad capacitor on the power board but replaced 3 due to seeing problems with them online. Anyways, TV comes on, and no picture but the backlight is working great. I do HAVE SOUND, what do you guys think? I will have to post a few pictures of the ribbon cables connecting the TCON to the lcd driver boards? (connect to LCD Screen by tab bonds) They have a weird greyish / metal stain on them a little, no burning though. Thinking about buying another T CON board, any input?
    -Zack
    Re: LN-S3251D - Replaced 3 Capacitors, Blank Screen, Backlight ON - Has Sound
    What DC voltage do you get at both ends of the fuses with ref. to chassis ground.
    • zdsh07p9
      • Nov 2013
      • 155
      Will get this when I get home, will also get pictures so I know exactly where to test, I am semi - handy with the Multimeter
      • Jim1590
        • Jul 2013
        • 98
        Test the voltage going to each board off of the power board. No picture sounds to me like a bad main board. TCon failures that I have seen (and in no way am I saying this is the case for yours) would still have a picture, just messed up.
        Plug TV in and ground black wire to the frame. I usually stick it in a empty screw hole somewhere far from where I am working (wall mount hole works good) and place the red probe to each wire in the harness on the board with TV on. The expected voltage should be printed right next to the peg for the wire.
          Actually t-con is the cause in more than 90% of cases of lit screen no image with sound.
          • Jim1590
            • Jul 2013
            • 98
            I get that foot in mouth problem often.
            • zdsh07p9
              • Nov 2013
              • 155
              Literally just got home guys, Thank you all for responding, very supportive. I have to study for a big exam so I will have to take voltages tomorrow. Tom66 I think, and hope, you are right because I ordered one yesterday
              • zdsh07p9
                • Nov 2013
                • 155
                Confirming that T-Con did fix this TV after capacitors were replaced as well. Thanks Guys
                • fixerupper75
                  • Oct 2014
                  • 125
                  • us
                  Have a LN-S3251D and after 15 minutes the screen go black with sound. When turn it off then back on the picture is back for about 15 minutes. Any suggestions???
                    Can you verify that the backlights are not on? If the backlights are on, then you need to monitor the DC Voltage feeding the fuse on the T-CON to see if it goes away when the problem occurs.
                    • fixerupper75
                      • Oct 2014
                      • 125
                      • us
                      Thanks for the quick response. I reseated the connector on the t-con board. And it has playing with no problems!!!!! I going now place the back panel on to see if is holding in the heat. Which may be causing the boards to over heat. Again thanks for the quick response ������
                      • mecha1166
                        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                        by mecha1166
                        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                        11-25-2024, 05:22 PM
                      • mrtek
                        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                        by mrtek
                        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                        11-26-2024, 09:58 AM
                      • Chrissygizmo
                        samsung galaxy ao2s very temperamental after screen replaced
                        by Chrissygizmo
                        Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                        Ive eventually managed to get it on and working but it's very temperamental...
                        The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                        05-26-2024, 12:05 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • triplefour
                        TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                        by triplefour
                        Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                        no change to display when disconnect tcon
                        no change to display when disconnect panel cables (both sides, one at a time, etc-)
                        can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                        also can faintly see a black cloud in the center of the screen. a darker area.
                        color of screen is backlit black screen which basically looks gray
                        12v present at TCON fuse
                        other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                        10-28-2021, 01:00 AM
