strange volt readings.
  • nomoresonys
    • 12330
    • U.S.
    getting 3.22 volts from bl-on pin from av board and 5.36 from bl-on pin from ps, both readings are with boards unplugged at cn303, which is the connector for bl-on, but with the connector plugged in it reads .18 volts, does anyone know what this means, THANKS.
    Re: strange volt readings.
    Make? Model? Does this belong in a different thread?
    • Repairtechlcd
      • Nov 2013
      • 12
      • Malta
      Try applying +5v from a bench psu to the bl-on input of the inverter and see what happens.
      Before doing this,check the resistance from bl-on input of the inverter for any s/c .As you unplugged the whole connector,you may have inadvertently taken a floating voltage reading .
      Regards
        "getting 3.22 volts from bl-on pin from av board and 5.36 from bl-on pin from ps" The BL_ON signal form main board is routed through the PS board for clean wiring, so the BL_ON output of the PS board should be the same at the input of the PS board, input into one connetor is directly connected to the output connector, same for the dimming control signal. To force BL_ON on the inverter board, you have to diconnect that line first otherwise the main board which is forcing that line low will not allow the BL_ON to swing HI due to BL_ON is stuck LO on the main board.
        • nomoresonys
          • 12330
          • U.S.
          NO this thread is right where it belongs.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Well providing us with Make, Model and pics would be a start to knowing this
            • nomoresonys
              • 12330
              • U.S.
              NOT in the mood for any smart ass comments, so if you brits can't be helpful, then go put your smart boy comments some place else.
              • newtothis
                • Mar 2013
                • 1556
                • england
                Well we are here trying to help and you telling us what make model etc would be a start, but since you have an attitude like that get help from somewhere else
                Any users of this forum should read the sticky and know to put this info in the thread title.
                We can't help anyone without knowing what we are helping with, TBH I'm not in the mood for your arsey attitude. Goodnight
                • nomoresonys
                  • 12330
                  • U.S.
                  Just get off my thread idiot
                  • nomoresonys
                    • 12330
                    • U.S.
                    you better go try ganging up on someone else, us yanks don't take crap from anyone boy.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      I think your stay here will be very short with comments like that, I will say no more
                      • nomoresonys
                        • 12330
                        • U.S.
                        I seriously doubt you will say no more, I think your a lonely boy....with no one to talk to.
                        • Mcfeetroy
                          Fishing bite alarm drains battery
                          by Mcfeetroy
                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                          08-01-2025, 03:52 AM
                        • MisterAIL
                          PS5 digital / No Power / No Beep / Good power supply
                          by MisterAIL
                          Brought a non functionnal PS5. Apparently only a bad PSU...
                          No beep, nothing.
                          After some tests i found this :
                          - PSU is fine (12 volts stable)
                          - 12 volts line is shorted
                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                          - By the way, nothing change. No signal, no power, no beep.
                          Mesuring all rails with my workbench psu (12 volts input)
                          - 0.00 amp drawing
                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                          03-12-2024, 03:24 PM
                          12 volt switching power supply modification to 14.5 volts before blocking diode add
                          I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
                          I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
                          One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
                          04-11-2021, 11:01 AM
                        • EasyGoing1
                          Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
                          by EasyGoing1
                          I don't know the first thing about where to even start looking for the result I'm looking for ... but what I want, is a circuit ... or maybe a certain transistor ... that will remain "closed" when the voltage at the base is 5 volts, but when that voltage gets to 4 volts or less, I need that transistor to turn on - preferably with maximum saturation. I would prefer that it also does not even turn on a little as the voltage approaches 4 volts, but remains closed until that voltage hits 4 volts.
                          Now, it would be OK if it had some kind of marginal transition from zero saturation...
                          01-08-2020, 06:06 PM
                        • Mark R
                          The Overseas Only Kenwood Model KR 790
                          by Mark R
                          I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                          The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                          09-23-2025, 08:27 PM
