Does anyone know what value this capacitor is?
Help with Film Capacitor Value
Re: Help with Film Capacitor Value
It looks like X/Y Safety cap .0015 uf 250VAC?
What section of the circuit it is used in?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Its in a BN44-00197A PSU.
This problem has me stumped... TV takes awhile to turn on, but once its on, you can turn it off and on with no problems or delay. Sounds like BAD CAPS! But there aren't any!!! I even checked every cap with my esr meter and they are all good.
Even tried heating the PSU with my heat gun but it doesn't speed the boot process... I swear my luck with these strange problems...Comment
That is the safety cap for AC line noise suppression, not needed for the board to work. I would check all the DC output voltages of all the secondary side output connectors when it is working and when it does not work.Last edited by budm; 11-13-2013, 06:13 PM.Never stop learning
by MORETTIGIANTitle:
Capacitor detached from PCB – RTX 2070 Super Founders Edition
Description:
During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
I did not notice it detaching, so I am unsure of its original location on the PCB.
Procedure performed:
- Removed backplate
- Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
- Reapplied thermal compound
- Reassembled card
Observed behavior after reassembly:
- GPU powers on and operates normally under...11 Photos -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
I hope these photos make it clear which component I am referring to:
(yes, the soldering is a bit botched from removing the blown one, I know)
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
I know that these capacitor will not last as long as nichicon capacitor...-
Channel: General Capacitor Questions & Issues
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
- Loading...
