Sony no image, no sound and no standby flashes
  • Danga
    • Nov 2013
    • 10
    • Colombia
    Well, for all the LCD TV Repairing masters.
    I've a LCD TV with the following symptoms:
    - No StandBy flashes, just Green Power Led steady as normal
    - No image, no backlight and No Sound. Even by changing input, volume, channels. Even by trying to enter service mode or whatever
    - I isolated the PSU and tested it and it gives all the voltages
    - Also, I isolated the Inverter and just by connecting it with the PSU it works properly illuminating the lamps
    By measuring I've found:
    - BL-ON, TCON-ON, DIMMER are 0V
    - BL-ERR is 3V (but the Inverter don't use it)
    - TCON-12V do exists properly if I set TCON-ON. But I tested it without connecting the TCON board
    I inspected all the boards (PSU, Inverter, Main, TCON) and there are no blown/bad components or fuses.
    So I think that can be the board, unless there are some kind of protection that I didn't check. The only place that I've not seen is under the cooler (I think the main cpu).
    I want to repair the board cause till now I didn't get a new one, and because I want to learn something.
    I've good electronics and repairing background, but this is my first LCD TV repair attempt.
    It is a Sony Bravia KDL-40EX407 with 3 years of normal use. The best schems what I found are KDL-40EX500 and KDL-32EX302.
    A curiosity: by following the traces of TCON-ON it seems that the signal have to come out from an AND gate being one input HI from microcontroller but the other input LO cause there is nothing more connected than a resistor o capacitor (I didn't identify it) to GND. I don't know if somebody have traced the proper origin of TCON-ON.
  • kenny1070
    • Oct 2013
    • 65
    Re: Sony no image, no sound and no standby flashes
    Reconnect everything and retest the power supply voltages to the main board - stand-by , regulated and un-regulated vdc (typically about 3.3 , 10 , and 18 vdc).
    Do you hear the main relay click when the set is first plugged in ?
    Do you hear the power-on relay click when the set is turned on?
    With the absence of sound and backlight - it sounds more like a command
    "power-on" problem.
    I can't find a schematic for this model - and without pictures it is very hard to help.
    But try these suggestions and let us know what you find.
    • kenny1070
      • Oct 2013
      • 65
      While the TCON board will handle pixal configuration (how it actually looks on the screen) -
      The sound , backlight , and actual video signal itself are usually delivered from a different area of the system - for example:
      - A/U board (or a/v)
      - Main board ( or b/u)
      - Inverter board
      Hope that helps
      • Danga
        • Nov 2013
        • 10
        • Colombia
        I reconnected everything and tested it:
        The result is "no relay-click sounds" and the voltages as I said before, that is STBY,ACOFFDET,PWRON,BL-ERR=3.3V
        BL-ON,DIMMER,TCON-ON=0V
        12V and 24V are fine
        • capkid
          • Oct 2010
          • 1339
          Sonys are known for panel and main board issues. There are people who repair them, but I'm not sure if a BGA or some other component goes bad or detaches.
          LG Plasma Mal-Discharge Correction Service
          • Danga
            • Nov 2013
            • 10
            • Colombia
            I found that schematics of KDL-40EX500, KDL-40EX400 or KDL-32EX302 are similar to my KDL-40EX407
            • Bob Neely
              • Oct 2013
              • 41
              I am having a problem with the KDL-40EX500. I found a burnt cap C6332. Can you tell me on the schematic what the value is and if there is another one on the board? Thanks for any help.
              • CHOOKY
                • Nov 2013
                • 16
                • australia
                Hi l have a LG 50PG20D, no sound no picture. screen goes grey then switches off 3 times. Over time got worse took a while to go on .......now no sound or picture anymore. LG repairer could not fix it no parts he said it could be EBR42472903/EBR42472802 don't know if he is right because he could not get the part to try. Can l fix the problem myself. Have looked around can't find anything burnt out.
                Would appreciate help Thanks....don't have a TV to watch now
                Thanks from Chooky in Australia
                • ChaosLegionnaire
                  by ChaosLegionnaire
                  09-13-2022, 09:02 AM
                • B0r1s
                  Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                  by B0r1s
                  PSU - BN44-00878A
                  Symptoms:
                  The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                  A weak clicking sound was coming from the transformer.
                  Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                  Progress:
                  After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                  01-17-2023, 04:58 PM
                • brithepi2k
                  Sony KD-65XE8596 no standby light
                  by brithepi2k
                  I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                  cheers...
                  09-06-2025, 02:22 PM
                • iglitare
                  Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                  by iglitare
                  i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                  Backlight seems to work, Sound (Setup menu after reset) works.
                  If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                  Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                  With my small knowledge i would think at least the cables are good.
                  Can this happen because of a bad tcon board?
                  Or is it always a bad/shorted...
                  09-04-2025, 07:13 AM
                • odie34
                  Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                  by odie34
                  I am a hobbyist (not a professional) so please be gentle...
                  I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                  I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                  02-18-2024, 09:11 AM
