EEFL tubes for 32 inch LG panel
  • Clydeuk
    • Jan 2012
    • 193
    hi does anyone know a cheap source of tubes, I have a 32 inch LCD here with a few bad, they are EEFL rather than CCFL, the panel is an LG-Philips. cant seem to find anyone who does them so thought i'd try here to see if anyone can help
  • vinceroger69
    • Mar 2012
    • 6714
    Re: EEFL tubes for 32 inch LG panel
    can you upload a picture of one with exact measurements of it as i parted out a 32in lg a few weeks ago and have got some tubes still
    • Clydeuk
      • Jan 2012
      • 193
      Thanks for the reply, hope these pictures send I've not done that before, and sorry for the quality I hope it's good enough. Measurements I've taken length end to end is 75cm, diameter of the end cap is about 3mm and tube diameter about 2mm. Panel type is LC320W01 (SL)(A1) and is from a Logik TV (Vestel)
      I damaged the tubes whilst trying to repair the inverter I fitted an incorrect value SM capacitor and caused arcing, the failed tubes now only light on the ends, about 6 have failed.
      • johnboy1313
        • Nov 2012
        • 1959
        Look on Craigslist for ads looking for broken TVs. They may have parts laying around.
        • Clydeuk
          • Jan 2012
          • 193
          I'll have a look there, I'm also keeping an eye on ebay for panel damaged sets that might be salvageable, the trouble is I keep coming across repairable sets that are too good to use for parts. As far as I know only LG use the EEFL tubes in their panels.
          • johnboy1313
            • Nov 2012
            • 1959
            I've succesfully replaced EEFL's with CCFL's. I just soldered the leads into the clips.
            https://www.badcaps.net/forum/showth...dp42848&page=2
            • vinceroger69
              • Mar 2012
              • 6714
              clydeuk i take it you are in the uk? regarding postage etc will find the tubes later and measure them the ones i have came out of a lg 32 so you need say 8 if i have got them?
                Panasonic IPS displays also use EEFL.
                • Clydeuk
                  • Jan 2012
                  • 193
                  Hi thanks, yes I am in UK (liverpool) I cant remember exactly how many tubes the panel has, I think it was 12 or 13, but I have pulled out the bad ones, I think 6 in total. One or 2 of the bad ones did eventually perk up the longer the set was left on, but always reverted back to just the ends lit when restarted, the effect on the display is very noticeable in the bad areas. LCD matrix itself is perfect so it would be a shame to ditch it, especially since I've fixed the main fault on the set (power supply).
                  Don't even think I have any CCFL tubes this size, I have a few pulled from a 26 inch panel, and I have a 42 inch LG panel (cracked) that will have EEFLs but obviously too long.
                  I'll add that 3 of the tubes I pulled will no longer light on the ends due to my clumsy feet standing on them :eek
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    looks like i have 8 of these defo 75cm long end cap length just over 3 cm let us know.
                    • Clydeuk
                      • Jan 2012
                      • 193
                      Hi sorry I've been away a few days. If you can let me know how much you want for the tubes plus postage I'm definitely interested as I'd really like to box this set off. I've temporarily reassembled the display as I don't want any accidents which is very likely with me lately.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        sent you a pm cheers
                        • Clydeuk
                          • Jan 2012
                          • 193
                          Hi. still looking for some of these tubes, vince sent me some but unfortunately most got damaged en route
                          If anyone has a broken 32 inch panel (LG) that would be suitable, I can collect from north west England if that would help prevent damage to the tubes.
                            Hi Clyde, I'm pretty sure I have a 32" LG panel in my basement from an older Vestel. Not sure what tubes it has, but it's yours. (I've also two 32" Samsung panels, both dead screen, CCFLs good too.)
                            Leeds LS4 if you want to collect, PM me.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              ive still got some tubes but im in warwickshire i packed them well i thought but we all know what royal fails like haha
                                • 31187
                                if you need to post tubes,
                                do what the chinese do - wrap them in bubble-wrap & shove them into a length of 2"/50mm plastic drainpipe.
                                • Clydeuk
                                  • Jan 2012
                                  • 193
                                  Hi
                                  I did see you had these panels Tom, just the post was some time ago and I assumed they'd gone. Will send you a PM regarding picking them up, I'm busy nights this coming week so it may be the week after if that's ok.
                                  The ones Vince sent were packed very well, I couldn't see any damage to the package, I think about 3 out of 8 survived the trip I wonder if Royal Mail dropped the package or put something heavy on top of it.
                                  It is an older Vestel that I have, as far as I am aware LG have always used EEFL in their panels, certainly the ones I've encountered so far. Someone has suggested using CCFL, not sure if that's a good idea for so many tubes, maybe the odd one, I think the inverter might object and shut down, though it does appear to run with tubes missing.
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    that does works, I had 50 CCFL for 19" monitor coming from China to the USA, all arrived safely ship in a PVC pipe.Deliver by DHL.
                                      I've left the panels in the basement of the old house - will have to check with old room mates to see if I can get access. Just let me know when you are free, I will try to find a time to meet them.
                                      • 8ternity
                                        • Apr 2013
                                        • 103
                                        Check here :
                                        http://www.iccfl.com/index.php?cPath=168
                                        Also here :
                                        CCFL Warehouse
                                        These ??
                                        http://www.ccflwarehouse.com/30x738mmeefl.html
                                          HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                          09-07-2024, 05:50 AM
                                          HP ProBook x360 Fortis 11 inch G9 Hybrid (2-in-1) Specification for Upgrade or Repair
                                          This specification for the HP ProBook x360 Fortis 11 inch G9 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Fortis 11 inch G9 boardview and Fortis 11 inch G9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
